Gearbox oil
06-02-2008, 09:08 AM
Gearbox oil
Hello all!
I am going to change the oil in my gearbox soon before it goes on the car, it is a W58 from a supra not a T50. What oil do people reccomend for this? what rating, etc. thanks |
06-02-2008, 09:43 AM
Gearbox oil
SAE 75-90 GL4 NOT GL5 !!!
AE86 FANATIC!!! |
06-02-2008, 07:02 PM
Gearbox oil
Couldn't find 75W-80 GL4
2 Different shops only had: 70w-80 gl4 80w-90 gl4 75w-90 gl5 as you made out gl4 was more important then the viscosity I went for 80w-90 gl4, hope that will be ok? I only got 1 litre, think I need more don't I? |
06-04-2008, 12:16 PM
Gearbox oil
bump is 80w-90 gl4 ok then?
How much should I put in? |
07-28-2008, 02:33 AM
Gearbox oil
Xaerob Wrote:bump is 80w-90 gl4 ok then? Hi I have the same question than Xaerob.. but in my case I use a T50. I need to know how much is the right quantity of oil that I have to put in. Ah.. the T50 in my car is for daily use. Thanks |
07-28-2008, 05:25 AM
Gearbox oil
80-90w GL-4 is fine
Remove the shifter and pour in 2L. You'll be fine. Andrew |
07-28-2008, 09:12 AM
Gearbox oil
You are supposed to fill it using the plug on the side of the gearbox. Squeeze in oil until it is level and starts coming out of this hole, which is about half the gearbox, its supposed to be done with gearbox on the car like this.
07-29-2008, 04:05 AM
Gearbox oil
.3L overfill won't hurt anything. Stock capacity is 1.7L and comes overfilled from the factory iirc.
Andrew |
07-29-2008, 05:01 AM
Gearbox oil
I use Motul MT90 for the tranny fluid. It saves on the synchros.
09-09-2008, 05:39 PM
Gearbox oil
Does anyone have experience with Motul Gear 300?
I'm not shure if it is the right one, coz on the site, it's writen: API GL 4+5. Is that somekind of hybrid? http://www.motul.de/i/prd/prod_auto/gear_300.htm |
trans oil, lsd oil change | Apolan | 9 | 16,997 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,137 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,693 |
Oil Presure and what oil i have to use? | CHACAMAN | 4 | 5,340 |
08-27-2008 05:35 AM Last Post: F0Bman |
High engine oil temps - oil cooler discussion | SutteR | 28 | 22,947 |
06-08-2008 11:23 PM Last Post: eight-six |
