Gnugfur of Norway! Viking power (56k, go learn russian)
12-22-2009, 12:26 AM
Post: #41
Copied right out of the s-tuningparts.com description
Quote:Ultra Racing Subframe Brace AE86. The Ultra Racing lower arm bar is designed to reduce the flex of the vehicle chassis where it is connected by the lower wishbone of the suspension system,thus to lessen the distortion of the vehicle lower suspension when it is under load,especially during hard conering.It is installed at the lower mounting points between the left end right suspension and the vehicle chassis.Tremendously improving the stiffness at the area where the lower arm is connected to the vehicle chassis.The Ultra Racing lower arm also keeps camber accurate during hard cornering.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
[Image: AEU86 AE86 - Gnugfur of Norway! Viking p...n russian)]
12-22-2009, 12:36 AM
Post: #42
I heard few things about them on other car brands. but still not yet about ae86.
12-22-2009, 12:56 AM
Post: #43
lower arm = lower control arm. we are talking about the "tension control rods" (tc-rods) and they dont have anything to do with cornering. they just keep the suspension leg at place by making a triangle with the lca and the chassis rail.
yes i browsed through UR-s explaination page and thoes are right but you obviously cant apply all stuff to all cars chassis. yes you can connect your lower control arm mounting points together to strenghten that part of the chassis in theory. but on the 86 i dont think its necessary since there is the subframe which can handle the same job.
that thing called front lower bar that thing which mounts to the lca's and the tranny mounts could be good, i dont really know but i dont think the tranny mounting points were designed to bear the flex caused by the front struts. no, not at all.
allright, thats my opinion, im finished Smile
btw that engine looks really promising!
12-22-2009, 01:11 AM
Post: #44
Lajoosh Wrote:lower arm = lower control arm. we are talking about the "tension control rods" (tc-rods) and they dont have anything to do with cornering. they just keep the suspension leg at place by making a triangle with the lca and the chassis rail.
I totally agree with your theory. But i wont be crying if this brace doesnt have all that of effect. Smile
Looking forward to getting the engine. Im only missing a turbomanifoil for it. Then i'll be ready to start building up the entire car when it arrives.
Im most exited about the tranny. It's a 6 speed tranny. Thumbs up!
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
12-22-2009, 10:24 AM
Post: #45
@Lajoosh, the braces "could work". Closing the transmission tunnel is the single biggest theoretical upgrade you can do to an AE86 short of installing a cage. The gearbox mounts straight into the chassis legs, so the connection will be fine.
The front tie rod brace usually does less. It certainly won't hurt anything more then weight, since the tie-rods pivot through their bushings, not their mounts.
12-22-2009, 05:25 PM
Post: #46
Gnugfur Wrote:Im most exited about the tranny. It's a 6 speed tranny. Thumbs up!
tranny like this... xD
Braces help tighten, but spot or seam welding chassis more effective and cage are the final solution.
I reccommend rear brace inside the cabin to reduce flexing too Thumbs up! hatch is a big hole on 3 door! Mine mounts directly to where rear seat backets go. Even without cage it really stiffens the rear significantly!
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
12-22-2009, 05:44 PM
Post: #47
My main problem is. That i have to build everything as anonymous as possible.
If i have a roll cage, the registration goes out the window the same day as i get pulled over.
All of the shiny parts i got and am getting, i have to camuflage, paint black and hide away as good as i can.
Since almost nothing's legal in Norway
When parts have "Shiny Shiny Go fast" written all over them. Im doomed.
So im going to do the same as we did on our turbolaurel. Paint everything black.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
12-22-2009, 10:10 PM
Post: #48
Gnugfur Wrote:My main problem is. That i have to build everything as anonymous as possible.
i understand your pain! Confused
12-22-2009, 10:28 PM
Post: #49
sweet project,
Luxembourg is the same, chrome/anodised/polished, and so on, are a nogo at the local Mot authorities, and its just one company who has the monopoly all over luxembourg... could just blame them all night Smile
280z '75
audi S4 B5 '99
KE25 '71
12-23-2009, 11:56 AM
Post: #50
Heh... nothing that you can compare to our country Slovakia (or Slovak Republic) If you want AE86 it's impossible to register it. All will turn against you because it is a old crap car (in their eyes). Maybe the one thing you can do is to write on international tribunal that you are discrimined at least you can have a good feeling about doing it but i think you will still end with " Go away pal and leave it".
I think the main problem is that there is no information on this cars because of Slovakia was no democratic state before 1990 so nobody imported those cars before so the dealers have no official technical description to the car ( I got pissed 3 times to asking them for help).
The other thing is that you need to pass MOT ...that is impossible because just mentioning the build date they just tell you "can't help you go away" ...no matter how shiny the car is you cannot pass.
So what i was doing ...well figure it out... i was having 4 AE86 coupes to this time but i am getting older and have more responsibility so my last one coupe is waiting 5 years now in garage waiting just one year to get it registered as Oldtimer... Yeah the only thing that you can do ...so that is how it in our country goes.... Thumbs up!
85' AE86 GT coupe lifetime project since 2005
  Hei from Adelaide South Australia via Bergen Norway Kid Karola 36 45,827 12-09-2011 04:29 PM
Last Post: Eircamae86
  Hello from Norway Rascal21 3 5,602 11-11-2008 12:18 PM
Last Post: Mux213
  Finally! Blue hatch owner from Norway. Syns 6 6,618 07-30-2007 02:07 AM
Last Post: Apolan
  New kid on the site..faz with pix(56k no no) faz 9 7,450 05-07-2007 08:25 AM
Last Post: joe69
  Hello from Norway :) (newb ae86 ownership Q's) MiRo 3 4,264 01-22-2007 06:38 PM
User(s) browsing this thread: 16 Guest(s)
