01-12-2005, 12:16 PM
Post: #41
mo-racing: ZaX needed some pics of T-50 internals and replacing sychromesh. Intake manifold welding was done because at the welded points (between bolts) the T3 adapter was wider than the manifold and gasket, so there was a slight possibility of air escaping from there. Now, the welds have increased the width at those specific points, so the gasket and T3 adapter fit spot on.
Ivan: The injectors came with the motor. They are not new. I'll ask for you though.
01-12-2005, 12:39 PM
Post: #42
good luck with the synchros. i did not change them this time couse you have to pull out every singel gear and synchro-body to get to 1st,2nd and 3rd gear. they are the last ones on the shaft Sad
note that gearbox parts are very expensive. the whole synchros and bearings add up to about 700eur +. i will stay with heel and toe driving and forget about the synchros Smile
still need some pics, zax?
01-13-2005, 11:50 AM
Post: #43
ALMOST THERE GUYS!
Engine and gearbox are in. Wire loom is NEW. New cables, custom made, only 2 cut wires.
You can see why the intake manifold was welded in the T3_adapter_InPlace picture. Now it fits perfectly.
Should drive off on Saturday afternoon, hopefully Thumbs up!
01-13-2005, 11:55 AM
Post: #44
Here is Tasos the mechanic (tall guy!), assembling the gearbox and Vasilis the electrician working on the loom
01-13-2005, 12:02 PM
Post: #45
Good going man! Really cool to see!
01-13-2005, 12:21 PM
Post: #46
Nice. What did you do with ECU??
01-13-2005, 12:39 PM
Post: #47
Me? I didn't do anything with it Tongue
Seriously now, I prefer to leave the electronics stuff to the specialists. To answer your question, I don't know why he opened it, probably to check the circuitry.
Can anyone tell me what makes a racing clutch disk and why powerful cars always have 3 spoke or 4 spoke disks?
01-13-2005, 12:59 PM
Post: #48
Dorito,
the perfect look on your engine bay makes me sick...
and jelous...
Lucky Bstrd.
See you tomorrow...
[Image: AEU86 AE86 - Greek AE86 restoration/modification (pics)] http://www.jdmbits.com
01-13-2005, 01:11 PM
Post: #49
i see. T3 adapter to remove TVIS.
(you have to tell us later what power this makes at top end and what is lost at lower revs if you have an old dyno plot to compare)
3 or 4 spoke clutches? i just know that you get more pressure when you reduce the survaface. maybee the new clutch-material needs more pressure to work right? not shure on this.
01-13-2005, 01:15 PM
Post: #50
re nmwisima it's not a matter of luck! It's matter of priorities in fund allocation (ask my previos girlfriend Big Grin ).
Luckily my current girlfriend has joined me on track (with the mini) twice already and appears to be very happy with track racing. Actually, the second time a friend with a S13 200SX joined us and she had a few sideways lap on the co-drivers seat. The funny thing is she came out screaming: "That was AWESOME! When do you get the Corolla back?!?!" Respect!
thanks mo!
  Full restoration... Blade1988 64 85,109 07-17-2016 11:53 AM
Last Post: McGlinchey
  Another danish restoration Duze 61 72,160 03-20-2016 08:58 AM
Last Post: Duze
  '84 ae86 restoration project HybriD07 19 25,187 10-13-2014 09:20 PM
Last Post: HybriD07
  TOYOTA COROLLA Ke70 - Restoration project cke70 34 51,064 07-02-2014 10:12 PM
Last Post: cke70
  Black Limited restoration slpery86 6 9,936 12-17-2013 09:22 PM
