Grip/ Proffrsional Track Coilovers
09-12-2016, 11:49 PM
I currently have a D2 drift spec suspension system on the car, and i really need a new one one way adjustable (bound rebound together on one adjustment) .
I am really thinking of: BC racing type ER two way, not coilover on the rear ( shock independent of spring) for 1500gbp ( bound rebound on different adjustments) MCN-AVO triple way, for 3.500 eur ( hi speed, low speed, rebound ) Anything proffesional track use ? Trible ( hi speed, low speed and rebound ) or at least double ( bound and rebound ) to sugest ? Has anyone tried any of the above ? Are they any good ? |
09-13-2016, 05:57 AM
It's a budget question, if you really want professional grade, then custom made KW, tailored to your use is the answer.
AE86 ex-daily |
09-13-2016, 07:59 AM
If you want the best get ohlin or reiger and get it custom specced for youre ae86 with corner weighting with you in it.
Prepare to pay an arm and leg |
09-13-2016, 10:15 AM
Something is not right here.... Professional coilovers and you example them with BCracing?
I know BCracing has a line of professional coilovers, but hey... if you want to go pro just get some TEIN or Ohlins and you're good to go! You also have DG-5 that could supply you with a nice set. If it is a question of budget i would go for the BCracing obviouslly, knowing the limitations of them but you can already purchase them with swift spring which is actually a nice upgrade by itself. Regards |
09-13-2016, 12:30 PM
(This post was last modified: 09-13-2016 12:31 PM by d3nso.)
Tein are out of production...
Whats your budget? Off the shelf coilovers can work great but have you considered getting a set made to your specifications? Daily Beater: Civic EG5 Work in progress Car: AE86 |
09-13-2016, 01:56 PM
As is very apparent what is your specific use. Do you race professionally or are you just an enthusiastic track day racer.
Also regarding 2/3-way adjustability, to actually be able to profit from that you would need a lot of time, a very deep understanding of suspension and math. Also a plethora of sensors measuring everything consistently while doing many laps to gain anything from it. I intended to go down that route a bit more than a year ago and had to be honest with myself and admit it would be overkill in my case. AE86 ex-daily |
09-13-2016, 03:01 PM
d3nso, i'm a TEIN distributor in Portugal. TEIN still makes them.... As i evaluated the option for myself.
09-13-2016, 09:11 PM
(This post was last modified: 09-13-2016 09:13 PM by totta Crolla.)
and rear http://www.esapeltonen.fi/kuvat/iskarit/ohlinstappi.jpg From here: http://www.esapeltonen.fi An analogue brain in a digital World |
09-14-2016, 12:07 AM
(This post was last modified: 09-14-2016 12:08 AM by hachirokkos.)
I am going to use it only in track. I am a racer and the car is a proffecional race car.
I dont have a specific budget cz i am studying now, so the car will not participate in a race for several months . Sent from my SM-G900F using Tapatalk (09-13-2016 09:11 PM)totta Crolla Wrote:The prices are fot one shock only ? What are the recomendations of springs ? Sent from my SM-G900F using Tapatalk |
09-14-2016, 11:14 AM
(This post was last modified: 09-14-2016 11:16 AM by totta Crolla.)
Best to contact the manufacturer as linked above for prices. Check also that the strut length will allow enough lowering for track, being a Finnish product it may be set up for rally use.
One very successful Touring car of the 80's used upwards of 700lb front springs. Tyres and body shell will have a bearing on the springs used. An analogue brain in a digital World |
Trackday with my 86 at mornay track | makkuro | 2 | 4,799 |
04-27-2019 03:44 PM Last Post: makkuro |
Wheel alignment settings for the track | Martynas | 9 | 12,562 |
11-23-2016 02:10 PM Last Post: Martynas |
AE-86 Track/Race car Spoiler/GT Wing Size and shape | hachirokkos | 5 | 10,790 |
11-26-2015 04:24 AM Last Post: asyrigos |
My grip trackday footage with my 86 | makkuro | 1 | 4,969 |
03-09-2012 10:08 AM Last Post: makkuro |
Grobnik track day - AE86 inside | ZaX | 2 | 6,117 |
11-17-2011 02:57 PM Last Post: ZaX |
User(s) browsing this thread: 20 Guest(s)
