Grip/ Proffrsional Track Coilovers
09-12-2016, 11:49 PM
I currently have a D2 drift spec suspension system on the car, and i really need a new one one way adjustable (bound rebound together on one adjustment) .
I am really thinking of:
BC racing type ER two way, not coilover on the rear ( shock independent of spring) for 1500gbp ( bound rebound on different adjustments)
[Image: AEU86 AE86 - Grip/ Proffrsional Track Coilovers]
MCN-AVO triple way, for 3.500 eur ( hi speed, low speed, rebound )
Anything proffesional track use ? Trible ( hi speed, low speed and rebound ) or at least double ( bound and rebound ) to sugest ?
Has anyone tried any of the above ? Are they any good ?
09-13-2016, 05:57 AM
It's a budget question, if you really want professional grade, then custom made KW, tailored to your use is the answer.
09-13-2016, 07:59 AM
If you want the best get ohlin or reiger and get it custom specced for youre ae86 with corner weighting with you in it.
Prepare to pay an arm and leg Smile
09-13-2016, 10:15 AM
Something is not right here.... Professional coilovers and you example them with BCracing?
I know BCracing has a line of professional coilovers, but hey... if you want to go pro just get some TEIN or Ohlins and you're good to go! You also have DG-5 that could supply you with a nice set.
If it is a question of budget i would go for the BCracing obviouslly, knowing the limitations of them but you can already purchase them with swift spring which is actually a nice upgrade by itself.
Regards
09-13-2016, 12:30 PM (This post was last modified: 09-13-2016 12:31 PM by d3nso.)
Tein are out of production...
Whats your budget?
Off the shelf coilovers can work great but have you considered getting a set made to your specifications?
Daily Beater: Civic EG5
Work in progress Car: AE86
09-13-2016, 01:56 PM
As is very apparent what is your specific use. Do you race professionally or are you just an enthusiastic track day racer.
Also regarding 2/3-way adjustability, to actually be able to profit from that you would need a lot of time, a very deep understanding of suspension and math. Also a plethora of sensors measuring everything consistently while doing many laps to gain anything from it.
I intended to go down that route a bit more than a year ago and had to be honest with myself and admit it would be overkill in my case.
09-13-2016, 03:01 PM
d3nso, i'm a TEIN distributor in Portugal. TEIN still makes them.... As i evaluated the option for myself.
Smile
09-13-2016, 09:11 PM (This post was last modified: 09-13-2016 09:13 PM by totta Crolla.)
and rear
http://www.esapeltonen.fi/kuvat/iskarit/ohlinstappi.jpg
From here:
09-14-2016, 12:07 AM (This post was last modified: 09-14-2016 12:08 AM by hachirokkos.)
I am going to use it only in track. I am a racer and the car is a proffecional race car.
I dont have a specific budget cz i am studying now, so the car will not participate in a race for several months .
Sent from my SM-G900F using Tapatalk
(09-13-2016 09:11 PM)totta Crolla Wrote:  [Image: AEU86 AE86 - Grip/ Proffrsional Track Coilovers]
and rear
From here:
The prices are fot one shock only ?
What are the recomendations of springs ?
09-14-2016, 11:14 AM (This post was last modified: 09-14-2016 11:16 AM by totta Crolla.)
Best to contact the manufacturer as linked above for prices. Check also that the strut length will allow enough lowering for track, being a Finnish product it may be set up for rally use.
One very successful Touring car of the 80's used upwards of 700lb front springs. Tyres and body shell will have a bearing on the springs used.
Tongue Trackday with my 86 at mornay track makkuro 2 4,799 04-27-2019 03:44 PM
Last Post: makkuro
  Wheel alignment settings for the track Martynas 9 12,559 11-23-2016 02:10 PM
Last Post: Martynas
  AE-86 Track/Race car Spoiler/GT Wing Size and shape hachirokkos 5 10,790 11-26-2015 04:24 AM
Last Post: asyrigos
  My grip trackday footage with my 86 makkuro 1 4,969 03-09-2012 10:08 AM
Last Post: makkuro
  Grobnik track day - AE86 inside ZaX 2 6,116 11-17-2011 02:57 PM
User(s) browsing this thread: 13 Guest(s)
