HELP!!! Tell me what these parts are, car not starting etc
08-29-2009, 02:18 PM
Right just a quick break down. My car has had perfect running redtops and blacktops in it. I have now temporarily downgraded to a blue top and its not working.
The thing wont start from the ignition anymore but I can bridge it from the starter to the battery and it starts fine (just not from the ignition anymore).
Also it took AGES to get it to run/idle, I have now managed to sort that, starts first time (by bridging battery and starter), but is absolutely gutless, has no power, struggles to do 50mph and has no acceleration (0-30mph in about 1 minute!!!)... and generally unresponsive.
I have had the cam covers off to check the cams are opening and closing in the correct order, tried checking the timing belt, checked compression (over 150psi each) changed plugs, leads, rotor arm, cap, dizzy, no joy.
I have however noticed a some plugs/connectors missing?
First of all this...
[Image: AEU86 AE86 - HELP!!! Tell me what these ...arting etc]
And this, someone has cut the wires from the back so I'm not sure what is going on there?
Also my reversing light is not working anymore? What the hell is going on???
08-29-2009, 08:43 PM
Ive sorted starter and reverse lights, still running like a c*nt though Sad
08-29-2009, 10:55 PM
Have you checked that you have the correct resistance in the injector
circuits ?? High impedence injectors = no resistors. Low impedence
injectors require the resistor pack in series with the injectors.
Cheers... jondee86
  lntermittent starting totta Crolla 6 5,419 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 3,998 08-31-2021 06:20 PM
  Axel anyway to tell the difference? MIGGZFSU 7 9,587 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  JDM trueno not starting. need help! kazi 8 10,920 03-12-2017 05:05 PM
Last Post: kazi
  20v Starting Issues mad.matt 10 14,179 09-24-2014 12:44 PM
Last Post: pack
