Help, Mot failure, High emmisions
05-23-2008, 12:48 AM
you do a regular new to you car tune up?
check the ecu, is it factory? knock on the cat, is it hollow?
[Image: AEU86 AE86 - Help, Mot failure, High emmisions]
05-23-2008, 03:04 AM
Again, the O2 sensor may not be functioning even if it is connected properly, the cat may have a piece of pipe knocked through it so it isn't actually doing anything, or it is just buggered.
These items don't last forever.
May have large overlap cams, bigger injectors with a standard ECU etc, etc.
05-23-2008, 07:23 AM
I don't think the problem is with your exhaust.
Do your spark plugs have black deposits?
http://www.AE86imports.0catch.com
05-23-2008, 06:28 PM
Thanks for all your replay's, there really good help and are definitely taking the stress out of the situation for me
After checking out my friends 86, as parrot said the third inlet pipe is blocked off, so I've blocked mine off and its running a lot smoother, especially when pulling away in 1st,
I'm going away for this weekend, but when I'm back I'm going to see if i can get the garage to put the 86 back on the emissions tester so i can see if the blanking of the pipe made a significant difference
Cheers
hopper
  High-beam warning lamp Mylesmck 4 1,780 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,899 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 23,647 12-31-2020 06:39 AM
Last Post: chenfon
  exhaust odor/idle MOT issue Ryo 7 7,804 07-15-2019 09:17 AM
Last Post: jondee86
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 36,685 08-21-2016 04:51 PM
Last Post: ray
User(s) browsing this thread:
