Manual steering conversion query
07-12-2008, 06:49 PM
I've taken out my power steering set up and replaced it with a manual one.
Everything fine apart from one bit - connecting the steering rack to the steering column. The shaft from the steering wheel is about 7-8cm too short to reach the rack Reason is the power steering joint is quite a bit higher as it sits on a resorvoir for the power steering fluid, so is actually closer to the steering column. I guess they are different parts, and assuming I'm going to struggle to find the manual steering bar bit, what else can I do to fix it together? Surely someone else must have come across this problem Thanks |
07-12-2008, 10:46 PM
IIRC speak to Paz, he has got around this with a bodge? Ideally track the joint down, its longer than the PS version.
Also maybe speak to Big Yin he has a tonne of spares and might have ne kicking about? http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
07-13-2008, 01:16 AM
Thanks for reply,
Just found a pic of what Paz has done. Also it seems a mk3 supra has the part that will fit too, which should be easier to find then a manual ae86. will give Big Yin a PM too. |
07-17-2008, 01:53 AM
Yeah the T3 spacers really help for extra lock.
07-17-2008, 02:00 AM
What you're looking for:
MKIII supra intermediate shaft. MKI mr-2 manual rack u-joint. Andrew |
20v Blacktop conversion.... | Mylesmck | 0 | 436 |
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 2,084 |
Wanted: 3-rib engine repair manual | Ivan141 | 6 | 2,416 |
09-09-2022 07:46 PM Last Post: oldeskewltoy |
AFM to Map Conversion | ps13michi | 3 | 3,103 |
Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 5,281 |
