I will Install origin Lsd used in my Ae86
10-08-2006, 11:38 PM
Hello friends,
I bought a Lsd of origin for Ae86 would like that you helped me in some points: What oil should I put? What pressure of Lsd should give? The LSD is used, do I have to do some wheelwork or special cares? Thanks, |
10-08-2006, 11:53 PM
I used Taf-x from castrol probably the best
KAE70--> http://www.youtube.com/watch?v=VJasjMGVd7k Ae86 daily drift car rebuild |
10-08-2006, 11:55 PM
sorry for gearbox taf-x for diff saf-x
10-11-2006, 12:39 AM
EQUIVALÊNCIAS DE ÓLEOS PARA TRANSMISSÕE Para AE86 API GL -5 SAE 90 Superior -18º C Lubrificante para Diferenciais Autoblocantes, recomendado para a lubrificação de eixos e diferenciais com requisitos de controlo de fricção do tipo "limited-slip" equipados com sistemas multi-discos de repartição de potência, em veículos ligeiros e comerciais. BP ENERGEAR LIMSLIP 90 API GL-5; ZF TE-ML 05C/12C/16E CASTROL Hypoy Ls 90 CEPSA AURIGA LS 90 ELF TRANSELF TIPO BLS ESSO GEAR OIL LSA FINA PONTONIC LS MOBIL INFILREX 33 SHELL Spirax Super GALP Galp LS 90 Fuchs Tital ls90 |
CD player install. | kazi | 8 | 8,573 |
02-21-2017 11:57 AM Last Post: banpei |
How to install 20V ITB on 16V head | Mr.komp | 7 | 11,459 |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 7,955 |
alignment issues after re-install of coilovers | NBU | 21 | 18,163 |
08-03-2013 06:18 AM Last Post: allencr |
bigport to smallport install | sketchy | 4 | 13,193 |
09-28-2012 10:24 AM Last Post: totta Crolla |
