ITB from bike engine ?
03-28-2009, 11:05 PM
Hi all
Is it possible to put some ITB's from bikes, supersport 600ccm class or bigger.
As much as i seen, all "R" bikes have throttle bodies diameter from 38 to 52mm (1000ccm class) so i believe it's totally possible to put them on 4AGE with right adapter.
Since those ITBs are really cheap (50-200€) and i can make adapter plate for free...
What do you say ?
Someone done that allready ?
03-29-2009, 02:30 PM
Yes it is possible:
http://www.aeu86.org/viewtopic/4age-in-a...car_/t/714
I know some other people did it as well, but I couldn't find any topic about that. I don't know what problems they encountered and what output it generated...
[Image: AEU86 AE86 - ITB from bike engine ?]
03-29-2009, 04:46 PM
yeah the Keihin FCR (flat slide carbs) have been a popular method in Japan for years (but expen$ive!) Many drift and circuit cars, notably on the Imamura ICBM AE86 and Team Running-Free cars. I believe used a 41mm throttle diameter.
http://www.keihin-us.com/fcr.htm
Classic clip of Yoichi Imamura in action from Option2 vol#32 Respect!
Feature from Drift Tengoku on his Silky House Trueno Thumbs up!
and just have to add the other half of that feature on Katsuhiro Ueo's even tho it uses AE101 ITB's
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
03-30-2009, 02:03 PM
What about MAP sensor.
As i understandd, all bikes have MAP on airbox.
Where can i put MAP (and which one) in this combination ?
thanks
03-30-2009, 08:12 PM
Hey man, if you want to get some ITBs
I can get you some pretty cheap
at a price thats reasonable.
Why not use something thats already proven to work???
03-30-2009, 10:57 PM
panda_tureno86 Wrote:Hey man, if you want to get some ITBs
Send some prices and ITB', with shipping to Europe, no problem Smile.
If the price is OK, i certanly won't mess with bikes ITBs Smile
04-02-2009, 03:04 PM
Here are some better pics of a FCR setup on Jay's car from Buddy Parts in Aust.
http://www.ae86drivingclub.com.au/forums...php?t=3066
04-02-2009, 03:06 PM
Uzelac Wrote:What about MAP sensor.
thanks
Uzelac you shouldn't need a MAP with carbs. rely on simple vacuum and mechanical fuel delivery (as opposed to an EFI setup on ITB's).
MAP measure manifold pressure so between throttle butterflys and intake, not in airbox. If you put the MAP line to the airbox, the ECU would think you were full load all the time airbox is atmospheric pressure.
MAP is quite responsive, better than airflow meters (even tho these are very good these days) problem with MAP on ITB's is that if you go off one throttle you have a very weak erratic pressure pulse.
Aside. Also with aftermarket management ECU you could use alpha-n (which is more responsive), if you are alpha-n tuning you are mapping throttle position TPS vs RPM.
04-02-2009, 03:19 PM
bike carbs larger than 32mm should be adequate for a stock motor. mikuni and weber sides though are 40/44/45mm they're outfitted with 32/34mm chokes from the factory (upgradeable to larger chokes obviously).
the only difference is available intake manifolds. they'll have to be custom fabbed.
i've got several bike carb projects in the oven using varying size carbs and ITBs (w/ megasquirt).
"Strictly All Things 86"
04-02-2009, 04:16 PM
Uzelac you shouldn't need a MAP with carbs....
Mate, your posts are real informing but aint' answers on my question Smile. Perhaps i wasn't specific enough, but i'm interested in ITB's with electronic fuel injection and MAP is important in that configuration.
regards
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,169 10-30-2013 11:18 PM
  Stock Bigport Engine + ITB?s?! pack 36 53,315 06-15-2013 07:19 AM
Last Post: jondee86
  Need engine,any engine Apolan 25 18,491 10-29-2006 06:55 PM
