Ignition lock problems :-S
10-17-2005, 09:26 AM
This morning I had to leave home without the hachi. I accidentally tried to use my moms key on it, and when I then tried starting with the correct key the lock was jammed stuck. I have tried every key I have, and have tried fiddling with the steering lock button, but nothing helped (it was not on the steering lock yet BTW). Frustrated to pieces I borrowed my moms car for the week...while driving past the hachi I thought what the hell I'll give it one last try, and then even the driver side door wouldnt open anymore..I'm frigging irritated...why do none of my locks work today?
Nothing has happened to my keys, both new copies and the original wouldnt work.
10-17-2005, 10:07 AM
aaaaa...get a new lock????? Thumbs up! the locks thread is prolly screwed up anyway......
[Image: AEU86 AE86 - Ignition lock problems :-S]
10-17-2005, 10:24 AM
Huh??? That's weird. Dumb question
I once had such a problem with my mitsu (I have three keys because both doors have different locks) but after using a lot of force I managed to get it unstuck... I wouldn't suggest using a lot of force because your key might break: mine was a bit bended afterwards. Undecided
10-17-2005, 11:51 AM
I think I'll take it apart when I get home next friday...not starting is unacceptable for my daily driver. I've had a similar problem before, but then it was the steering lock that was stuck. I doubt the lock is really ruined, this is not the first time I put my moms key in there and it never caused problems before...
10-21-2005, 05:35 PM
I followed up on banpei's advice and used the brute force method. Lucky for me it helped, and my key is not even bent! Bit weird though, my driver side door had the exact same reluctance to open, used the same method on that as well.
10-21-2005, 09:03 PM
i have lock problems as well.. well noot w/ the most used key (out of 3 in total). Other two go in nicely, but just dont turn none of the 4 locks.. huh..
10-22-2005, 12:04 PM
Ivan141 Wrote:I followed up on banpei's advice and used the brute force method. Lucky for me it helped, and my key is not even bent! Bit weird though, my driver side door had the exact same reluctance to open, used the same method on that as well.
Good to hear it worked and without bending the key. I still remember the "DOH" feeling after my key was bended. Lucky enough I managed to get it bent back. Wink
10-22-2005, 12:36 PM
Well I have 2 brandnew copies of the original key that I normally used..the old original key (I only have 1) is about 0.5mm thick due to wear. I would have broken that thing for sure if I had to use it.
  Ignition switch plug and wires Blaze0010 3 591 11-25-2024 12:29 PM
Last Post: Blaze0010
  Door lock disassemble RWD 3 2,306 03-17-2022 02:03 AM
  Big wheel problems gh0st 16 8,881 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,835 08-31-2021 06:20 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,105 07-18-2019 03:52 PM
Last Post: oldeskewltoy
