Inlet systems
09-22-2007, 06:14 PM
Inlet systems
I have just brought my first AE86 and am looking at inlet manifold /Carb modifications which is best twin 40s or the after market manifold with bell mouths that still uses the EFI system.
At the moment the car has the standard plenum but with a single bell and no filter.
The car has uprated cams and CPU only at the moment
09-22-2007, 10:15 PM
Inlet systems
it looks as oer throttle bodies similar patern as dcoe weber carbs, the manifold is for smallport head, sure its good but it looks almost new so the price will raise. but if you have Air flow meter version you must change to standalone ecu. with vacuum sensor and build an plenum for it.
http://www.86ers.org
09-23-2007, 11:06 AM
Inlet systems
I can offer bigport adapter for 40's.
  Smallport inlet manifold totta Crolla 6 4,288 01-17-2022 05:14 PM
  20v itb inlet manifolds totta Crolla 24 29,389 12-14-2012 12:21 PM
  Aircon: Converting R12 systems to R134A Lauren 1 5,467 06-04-2011 04:21 PM
Last Post: Lauren
  OBX Exhaust Systems robokill 26 43,175 05-08-2011 09:08 AM
Last Post: malejyetti
  inlet manifold Nismo 6 7,171 09-29-2010 02:17 AM
Last Post: Nismo
