09-29-2006, 06:54 PM
Post: #201
Thats quite reasonable....pitty about the front springs..I quite liked them: high springrate ( guessing around 4kg/mm) but high enough to clear any speedbumps easily...Guessing the car will suck more with the lowering springs.
09-29-2006, 06:58 PM
Post: #202
I would be surprised if it ever did pass in one go...
But I just know another garage would have found a gazillion other things to fail it on... the right rear caliper sticks and I think the saddle of mounting plate might be a little bit bent since it does not sit perfectly parallel to the brake disc. There is also a big hole in the chassis rail under the trunk...would be a failure point but no-one's ever noticed it because it's hidden behind the tank...you need to look just the right way through the little opening there to see it. This mechanic actually commented that the car is a lot better underneath than it looks on the outside... which is a relief compared to last years "do yourself a favour and bring it to the wrecking yard" comment. FABRICA MI DIEM, PVNC! |
09-29-2006, 07:12 PM
Post: #203
Well doesn't sound to bad...
09-29-2006, 08:34 PM
Post: #204
Ivan141 Wrote:This mechanic actually commented that the car is a lot better underneath than it looks on the outside... which is a relief compared to last years "do yourself a favour and bring it to the wrecking yard" comment.Atleast that is an improvement. ![]() But apart from the extra work it isn't a too big point to fail on. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
09-30-2006, 12:15 AM
Post: #205
![]() ![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-07-2006, 12:12 AM
Post: #206
Update 27893434:
-Fitted Koni yellow's all round -re-fitted the crappy Merwede/Cobra front lowering springs -fixed the steering joint dust cover (33 euro's from toyota...what a ripoff). -threw on senna's old airfilter and aluminium pipe results: -hopefully MOT/APK approved by monday -looks a hell of a lot better with the front down -steers a bit better too... -opening TVIS valves sound like porn with the 'sports'airfilter weird conclusions: -the springs werent actually that loose at all.. no different than last year when it passed inspection. -koni and they're f%ck#ng fine-threaded nuts...can never find replacements even when I have thousands of nuts available to search through. FABRICA MI DIEM, PVNC! |
10-16-2006, 12:49 PM
Post: #207
Got MOT yet ?
10-16-2006, 12:53 PM
Post: #208
Vervaldatum APK 9 oktober 2007
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-16-2006, 05:20 PM
Post: #209
Thanks Doc...she's APK approved once again.
![]() FABRICA MI DIEM, PVNC! |
11-15-2006, 08:00 PM
Post: #210
Ivan when can we finish your car!
My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 593,058 |
Another SR20DET conversion allmost done :) | peter møller | 7 | 15,899 |
Yay! Its now done and on the road! | Black Betty | 24 | 22,811 |
Bodywork in 3 steps | max_ae86 | 67 | 60,773 |
