Kris´s TOYO/KONI drift car
04-27-2005, 08:51 PM
I have been saving up a big load of parts over the vinter, & now i finally have started to adapt the car for the summers drifting days.
I decided to measure a bit more than i needed - & came to the conclusion that I could cut the strut´s the 40mm above the spring-plate. & there for i could still use the stock (cut) springs if i wanted to for the yearly MOT. I also found out that the Coilovers will fit the struts - which i first had measured that they would NOT fit. i also sanded down the struts & took the entire strut/brake assembly apart in oredr to paint them... Regards/ .............kristian I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-27-2005, 08:52 PM
Det ser inte bra ut kristian
04-27-2005, 08:57 PM
legend Wrote:Det ser inte bra ut kristian Not ??? ![]() ![]() ![]() ![]() I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-27-2005, 09:06 PM
more pics about what has happened...
04-28-2005, 09:26 AM
Kristian, why most aftermarket springs are shorter than stock ?
I can understand why they are stiffer, but why not use long springs even in shorter strut housing - if remove the lower perch and use longer coilover sleeve ? Maybe I miss something important here. |
04-28-2005, 10:26 AM
jamiemirror Wrote:Kristian, why most aftermarket springs are shorter than stock ? I´m using shortstroke shocks now - thats why ! K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-28-2005, 10:29 AM
Now it's clear. |
04-28-2005, 11:21 PM
decided to cut of the spring-plate today.
& adapted the coils to fit the strut exactly. I also bought some miniature bolts to lock the coils in place. the coils now rest on the weld that held the spring-plate in place - which sould be more than enough for the springpreassure. I also sanded down & painted the front calipers. I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
04-29-2005, 01:15 AM
looks nice....
kris why did you paint the rubber on the calipers???? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-29-2005, 11:36 AM
robokill Wrote:looks nice.... Cause i had no tape to cover them with K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
SR86 as a drift car | cle | 38 | 45,602 |
06-22-2012 12:11 AM Last Post: cle |
danish renovation, from rusty old banger, to nice drift car | katapouser | 15 | 19,226 |
12-23-2008 10:41 PM Last Post: katapouser |
