Kristians track setup
09-17-2005, 10:42 PM
Bastiaan...
Thanxs you for a great idea for a new forum
this last Wednesday i was supposed to go trackdriving at Sturup Raceway. (se picture of track)
But my broken diff -I´m having problems getting it apart - stopped me.
On the first of Octobre i´m going to Ring Knutstorp (se picture of track) just 12 kms south of me, for a whole day´s trackdriving with the Swedish honda Club.
My drift set-up is not that big in difference from the new track set-up.
Here are the differences:
Drifting set-up !
Front suspension: Coilovers to 0 percent (as soft as possible)
KÓNI´s set to SOFT
Rear suspension: KONI´s set to 85-95% stiffness
Twin swaybars installed & adjusted
front tires: TOYO T1-R 195/55-14, semi R-rated
front rims: 6,5 x 14
rear tires: TOYO Cleanproxes, 174/65-14, studless snowtires
rear rims: 6,5 x 14
Track set-up !
Front suspension: Coilovers set to 65% stiffness
Rear suspension: KONI´s set to 55% stiffness
twin swaybars still installed, but bolts loosened
front tires: TOYO R888 185/55-15 R-raded with Supersoft compound
front rims: 7 x 15
rear tires: TOYO R888 215/50-15 R-raded with Supersoft compound
rear rims: 8,2 x 15
09-18-2005, 12:11 AM
Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them.
09-18-2005, 12:14 AM
NoHachi Wrote:Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them.
i belive this set-up will kick som serious Honda V-tec ass Thumbs up!
09-18-2005, 02:25 AM
Quote:Front suspension: Coilovers to 0 percent (as soft as possible)
KÓNI´s set to SOFT
Doesnt this make the front re-act alittle to slowly??? or is that how you want it in drifting. I would have throught you would want about 45% stiffness so that the front isnt always absorbing all the bumps and changes in the corners. Cause being stiffer would allow better steering response wouldnt it? Confused
09-18-2005, 08:53 AM
Split this post so the announcement thread wont be filled up with subjectsSmile
Nice info krisSmile
09-18-2005, 10:52 AM
What's the speed differance between the R888 and the T1R in corners?
09-18-2005, 11:59 AM
mux213 Wrote:Split this post so the announcement thread wont be filled up with subjectsSmile
Nice info krisSmile
Cool Mux ! Cool
09-18-2005, 12:00 PM
Kir Wrote:What's the speed differance between the R888 and the T1R in corners?
Kir:
T1-R is a high performance STREET tire.
R888 is an R-rated racing tire with thread.
Differences" should" be A LOT !
Although i dont know yet.
Kris
09-19-2005, 09:54 AM
These Toyo are awesome. They have better grip as racing slicks!!! We are racing on kart tracks (we don't call it so, but I think its AutoX). I use GY Eagle F1 GSD3 - we were very competitive until one of our competitors bought them. Now we are 3-4 seconds behind. Even in wet (F1 very good on wet surface).
09-19-2005, 10:38 AM
What are the specs on spring you are using?
My konis when set on soft seting could not damper enough 8kg/mm coilover springs so car would bounce a lot.
Tongue Trackday with my 86 at mornay track makkuro 2 6,010 04-27-2019 03:44 PM
Last Post: makkuro
  Wheel alignment settings for the track Martynas 9 15,192 11-23-2016 02:10 PM
Last Post: Martynas
  Grip/ Proffrsional Track Coilovers hachirokkos 15 22,573 10-15-2016 08:26 PM
Last Post: NoHachi
  AE-86 Track/Race car Spoiler/GT Wing Size and shape hachirokkos 5 13,045 11-26-2015 04:24 AM
Last Post: asyrigos
  Grobnik track day - AE86 inside ZaX 2 7,180 11-17-2011 02:57 PM
