Levin - Trueno Questions
02-24-2012, 10:58 PM
Post: #31
Thanks!
02-29-2012, 05:58 PM
Post: #32
Any news banpei?!
03-08-2012, 02:32 PM
Post: #33
Got the connectors for the clearance lights. CE100 and AE92 models use them too! That part is solved!
New questions! I've got some problems finding the connector references for my relays, i have some images from them and i even got some more information via electrical schemes elsewhere on the car. The problem is that i can't find any reference from those 6 pin connectors. Is there any place on the web, or anyone that could help me get references? Or maybe find some other car sharing those same 6pin connectors. Same issue about the headlight motor connectors. Where can i find references from those? Those are easier to deal with, just cut the wiring and adapt some new male/female plugs. Regards |
03-08-2012, 02:43 PM
Post: #34
I lost you there after the third connector(s) - what do you need?
AE86 ex-daily |
03-08-2012, 03:04 PM
Post: #35
hahahaha true! Didn't read what i wrote.... Damn... so many connectors!
Just need some references about those, or any info from where can i get similar ones. =) |
03-11-2012, 06:54 PM
Post: #36
Got everything i needed except the male connectors from the clearance lights..... Where could i possibly find those?
Meanwhile.... My electrical scheme doesn't exactly match the manuals.... I'll explain everything My actual connector at the car (the white one) ![]() But on the Levin electrical scheme it is... ![]() ![]() The colours are different! What's escaping me here? Need some help please. Thanks |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 3,077 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 1,593 |
04-30-2024 09:46 PM Last Post: Mylesmck |
Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 6,081 |
11-05-2021 08:17 PM Last Post: gh0st |
Brake Bias Questions | mad.matt | 10 | 11,959 |
01-03-2019 04:54 AM Last Post: mad.matt |
wider rear axle,track width,suspension questions | ditn | 6 | 9,294 |
