Manifold/lambda problems
11-16-2009, 06:05 PM
Recently I installed new, custom made 4-2-1 manifold. After driving the car for few days, it doesn't work properly between 2-3k rpm when accelarating.
Could this malfunction be due to the fact that lambda is reading only 1 cylinder readings? Did anyone had similar problems?
Btw, engine is Blacktop 20V
[Image: AEU86 AE86 - Manifold/lambda problems]
DRIFT.HR
11-19-2009, 05:41 PM
Hey you have a leekun engnie Big Grin
Its always better to get lambda from the common pie to all 4 cylinders.
11-20-2009, 01:06 AM
Certainly... better to sample from the collector. But, there are any
number of aftermarket headers coming from Japan with the sensor
mounted in one of the primary tubes.
If it is a one wire or two wire sensor (non-heated) the end of the
sensor may need to be further into the gas stream. Does the end of
the sensor project out into the gas stream by the same amount as
when mounted in the factory location ??
Blacktop engines are well known for a mysterious mid-range stumble.
Sometimes a new sensor solves the problem.
Cheers... jondee86
  Lambda sensor wiring sam3007 10 6,469 05-23-2022 10:00 PM
Last Post: The Doctor
  Smallport inlet manifold totta Crolla 6 4,513 01-17-2022 05:14 PM
  Big wheel problems gh0st 16 10,827 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 3,582 08-31-2021 06:20 PM
Last Post: totta Crolla
  Problems Mintex M1155 pads Dino86 9 10,505 07-04-2017 11:22 AM
