More 4ac problems
07-18-2007, 07:47 PM
More 4ac problems
They seem to be never ending. I finally got the timing belt back on, and everything in place, tried to do the timing, and my hachi still runs like absolute junk. I KNOW it had more power before I replaced the timing belt. The distributor is all the way against the firewall, and I still can't get it factory timing (5 btdc) it will go to tdc, but thats it. Could my distributor be a tooth off? or could my timing belt be a tooth off? any help guys? Banging head Banging head Banging head Banging head Banging head Banging head Banging head
1971 Ford Mustang
1984 Hachi-Roku
http://www.club4ac.com
slowest AE86 club on the net Smile
09-09-2007, 06:07 PM
More 4ac problems
I just re-checked my timing and valve clearances on my 4ac yesterday. if you have a 4ac, the factory timing should be set at 10 degrees BTDC. If it's at 5 degrees BTDC, it should run like crap. Also, make sure you set your idle speed to 800 rpms + or - 50 rpms before you adjust the timing.
another thing i noticed, there seems to be 2 timing marks on my belt, but there should be only one mark that'll line up with the markings near the crank pully (i.e. 20 15 10 5 0 5) when adjusting with the timing light.
09-11-2007, 09:37 AM
More 4ac problems
surfingdrums Wrote:Could my distributor be a tooth off? or could my timing belt be a tooth off? any help guys? Banging head Banging head Banging head Banging head Banging head Banging head Banging head
For the first the answer is NO, but for the second question the answer is , Yes it could.
You have to make sure that the marks on the cam gears are totally looking to each other.
And there is a mark on the Block too, which must be looking to that on the pulley.
But, what is exactly the problem?
The engine is just sort o power, or it is working rough too?
[Image: AEU86 AE86 - More 4ac problems]
  Big wheel problems gh0st 16 12,158 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 3,991 08-31-2021 06:20 PM
Last Post: totta Crolla
  Problems Mintex M1155 pads Dino86 9 11,193 07-04-2017 11:22 AM
  4ac gearbox on 4age hachirokkos 2 7,627 05-24-2016 10:16 PM
  16v Bigport fuel problems Rascal21 1 5,786 07-04-2015 01:00 AM
Last Post: jondee86
