New server
04-30-2006, 10:22 PM
New server
As you might have noticed: the server is getting slower each week.
I've been busy getting things together for a few months now. A new server had been installed this weekend (just before queensday ) and I will try to get stuff over to the new server asap. As far as I've tested the server should be atleast five times faster, but probably due to having more resources it will be a bit more. The old server will be removed and sold for cash which will return into the aeu86.org cash-register. I'll let you all know when the move will happen Edit: oh, and the P4 sticker is fooling you. It is a used casing, the server runs on an AMD. > 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-01-2006, 09:27 AM
New server
It defies gravity!
05-01-2006, 06:05 PM
New server
Indeed. Either my DSL provider is starting to take their service seriously, or Art's magic has again done the trick.
05-01-2006, 09:59 PM
New server
Dorito86 Wrote:Indeed. Either my DSL provider is starting to take their service seriously, or Art's magic has again done the trick.I think the first: new server is not running the forum yet. Edit: to give you an idea, I've attached two picture of the cpu load. Normally a webserver will rapidly degrade performance over 50%, lucky enough we are a bit steady around 20 to 25 percent over the past month. However: if you look at the day graph you see a lot of peaks reaching 50% once in a while. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-02-2006, 07:48 AM
New server
Well I'm glad you sorted us out with a new server already.. good work.
05-02-2006, 09:08 PM
New server
Ivan141 Wrote:Well I'm glad you sorted us out with a new server already.. good work.Bad work you mean. I've just made a big boo-boo with the server tonight and it is not repairable. I'm going to collect it on thursday and reinstall the machine. Hopefully it will go smoother this time. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-03-2006, 09:44 AM
New server
Stay away from that delete command next time mate
Sorry to hear that you need to redo alot of work Hope it goes smoothly... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
06-10-2006, 09:47 PM
New server
Right. Took me not so long to reinstall it, but I didn't have the time to put it into the datacenter and move all stuff to it.
Anyway, last week I placed the server into the rack again, made sure it made backups each day Tomorrow evening (probably around 23:00) I'll copy everything to the new server and switch the servers. It could be possible the servers are unreachable, but I recon it won't take much longer than 10 minutes. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-11-2006, 10:49 PM
New server
I'm going to postpone this till tomorrow morning.
(too hot and I want to be anywhere but behind my computer now. ) 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-12-2006, 10:11 AM
New server
New server is up and running and you probably will notice th speed increase.
Server crashed last sunday | banpei | 17 | 17,460 |
10-25-2012 11:15 AM Last Post: banpei |
Slight problem with the server | banpei | 4 | 5,933 |
05-31-2009 09:34 AM Last Post: nmwisima |
Server outage on Friday 13th | banpei | 4 | 5,653 |
06-13-2008 04:29 PM Last Post: cavey |
Server problems | banpei | 4 | 5,959 |
06-10-2007 09:27 PM Last Post: Lipinhu |
Server problems | Mux213 | 10 | 9,622 |
01-04-2007 11:43 PM Last Post: banpei |
User(s) browsing this thread: 17 Guest(s)
