New server
04-30-2006, 10:22 PM
New server
As you might have noticed: the server is getting slower each week. Undecided
I've been busy getting things together for a few months now. A new server had been installed this weekend (just before queensday Tongue ) and I will try to get stuff over to the new server asap. Smile
As far as I've tested the server should be atleast five times faster, but probably due to having more resources it will be a bit more. Wink
The old server will be removed and sold for cash which will return into the aeu86.org cash-register. Tongue
I'll let you all know when the move will happen Smile
Edit: oh, and the P4 sticker is fooling you. It is a used casing, the server runs on an AMD. >Smile
[Image: AEU86 AE86 - New server]
05-01-2006, 09:27 AM
New server
It defies gravity!
05-01-2006, 06:05 PM
New server
Indeed. Either my DSL provider is starting to take their service seriously, or Art's magic has again done the trick. Thumbs up!
05-01-2006, 09:59 PM
New server
Dorito86 Wrote:Indeed. Either my DSL provider is starting to take their service seriously, or Art's magic has again done the trick. Thumbs up!
I think the first: new server is not running the forum yet. Tongue
Edit: to give you an idea, I've attached two picture of the cpu load. Normally a webserver will rapidly degrade performance over 50%, lucky enough we are a bit steady around 20 to 25 percent over the past month. Smile
However: if you look at the day graph you see a lot of peaks reaching 50% once in a while.
05-02-2006, 07:48 AM
New server
Well I'm glad you sorted us out with a new server already.. good work.
05-02-2006, 09:08 PM
New server
Ivan141 Wrote:Well I'm glad you sorted us out with a new server already.. good work.
Bad work you mean. Angry
I've just made a big boo-boo with the server tonight and it is not repairable. Crying
I'm going to collect it on thursday and reinstall the machine. Hopefully it will go smoother this time. Wink
05-03-2006, 09:44 AM
New server
Stay away from that delete command next time mateSmile
Sorry to hear that you need to redo alot of work Sad Hope it goes smoothly...
06-10-2006, 09:47 PM
New server
Right. Took me not so long to reinstall it, but I didn't have the time to put it into the datacenter and move all stuff to it.
Anyway, last week I placed the server into the rack again, made sure it made backups each day Wink
Tomorrow evening (probably around 23:00) I'll copy everything to the new server and switch the servers. It could be possible the servers are unreachable, but I recon it won't take much longer than 10 minutes. Smile
06-11-2006, 10:49 PM
New server
I'm going to postpone this till tomorrow morning. Undecided
(too hot and I want to be anywhere but behind my computer now. Smile )
06-12-2006, 10:11 AM
New server
New server is up and running and you probably will notice th speed increase. Smile
  Server crashed last sunday banpei 17 17,409 10-25-2012 11:15 AM
  Slight problem with the server banpei 4 5,923 05-31-2009 09:34 AM
  Server outage on Friday 13th banpei 4 5,638 06-13-2008 04:29 PM
Last Post: cavey
  Server problems banpei 4 5,954 06-10-2007 09:27 PM
Last Post: Lipinhu
  Server problems Mux213 10 9,607 01-04-2007 11:43 PM
