OEM LSD Question
07-10-2014, 07:20 PM
OEM LSD Question
Will the TRD plates fit into an OEM differential then ?
07-10-2014, 10:23 PM
OEM LSD Question
(07-10-2014 07:20 PM)totta Crolla Wrote: Will the TRD plates fit into an OEM differential then ?Would be news to me - but weir make an upgrade kit and also someone on here came up with a solution to fit an additional plate inside the OEM one on each side. AE86 ex-daily |
07-11-2014, 04:34 AM
OEM LSD Question
It should take a VERY LONG TIME to wear out those plates.
Did they pre-soak them & assemble it using plenty of lube on them? So what! |
07-11-2014, 05:40 AM
(This post was last modified: 07-11-2014 06:57 AM by heshan.)
OEM LSD Question
Yes looking at all plates that I have they seem more like t d ones than others. Must be due to being a JDM model.
Round edged cluch n spacers/washers. (07-11-2014 04:34 AM)allencr Wrote: It should take a VERY LONG TIME to wear out those plates. The diff was never removed by the looks of it so ideally the diff should be as old as the car and the clutch plates the same. (07-11-2014 05:40 AM)heshan Wrote: Yes looking at all plates that I have they seem more like t d ones than others. Must be due to being a JDM model. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-11-2014, 07:18 AM
OEM LSD Question
pics of the diff
Anyone can tell what this diff is by looking at it or tell me how to identify what the exact diff is? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-11-2014, 09:17 AM
OEM LSD Question
http://www.ebay.com/itm/JDM-TRD-LSD-Repa...9f&vxp=mtr
link which made me think that mine is a factory fitted TRD unit.. Its tough to find info on this JDM LSD unit.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-11-2014, 10:07 AM
(This post was last modified: 07-11-2014 10:16 AM by totta Crolla.)
OEM LSD Question
From the casing it looks like a TRD unit.
My TRD differential is noisy when using SAE 90 oil. The pictures contained in the post below should help you to confirm, notice the rough surface of the casing on the TRD compared to the OEM diff. http://www.thaiscooter.com/forums/showth...7-cw_ldVKs An analogue brain in a digital World |
07-11-2014, 10:25 AM
OEM LSD Question
I used to use 85w90 Toyota oil. What do u use?
07-11-2014, 10:26 AM
OEM LSD Question
75W140 LS only.
It looks like TRD unit: |
07-11-2014, 10:35 AM
(This post was last modified: 07-11-2014 10:36 AM by Ivan141.)
OEM LSD Question
TRD indeed, that changes the picture quite a bit.. that wouldnt break anywhere near as easy as an old OEM diff would, and it can make more noise.
BTW, I've never heard of factory fitted TRD LSD's...very much doubt it has been there from the factory. FABRICA MI DIEM, PVNC! |
OEM LSD modification | malejyetti | 40 | 53,490 |
06-23-2016 12:34 PM Last Post: pack |
OEM lsd rebuild kit and exterior parts | NightAddict | 6 | 7,989 |
01-07-2013 11:01 PM Last Post: T_AE86 |
ae86 oem lsd | Captainl | 3 | 5,116 |
07-05-2011 08:48 AM Last Post: Captainl |
difference when installing OEM or Cusco LSD | aussiefan | 3 | 4,332 |
09-27-2010 02:39 AM Last Post: assassin10000 |
Question about oem injectors (blue vs. gray) | Apolan | 12 | 12,348 |
08-13-2010 06:51 PM Last Post: superli |
User(s) browsing this thread: 14 Guest(s)
