OST-034: Noir Crowning
09-11-2015, 11:47 PM
#2 on left and #1 on the right
![]() On the intake side all I did was knock back the guides, and guide bosses, and made the bowls round to fit/follow the valve seats.... OH I also added a very gentle short side radius.... and opened up the bowls a bit as well. ![]() Here we are with 4 chambers, 4 exhaust ports, and 3 intakes finished... it got a bit too hot today, so I'll finish on Monday. ![]() More to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-11-2015, 11:54 PM
Nice work as always, pity I can't make it over this year.
AE86 ex-daily |
09-12-2015, 12:59 AM
(09-11-2015 11:54 PM)Bean Bandit Wrote: Nice work as always, pity I can't make it over this year. don't Nuke deals suck...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-15-2015, 08:38 PM
oldeskewltoy Wrote:OH I also added a very gentle short side radius.... and opened up the bowls a bit as well. ![]() and a bit closer of a view of the worked short radius compared to the unworked side Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-16-2015, 03:57 AM
Hi Dan
I wonder how my head flows compared to your numbers. My tuner says it flows 190 CFM @ 9mm lift and 20" of water...? |
09-16-2015, 06:22 PM
(This post was last modified: 09-16-2015 06:23 PM by oldeskewltoy.)
(09-16-2015 03:57 AM)harkes Wrote: Hi Dan You have a 16V... so we are comparing 20V blacktop to your 16V? 9mm is .354"... my intake numbers are 197 @.350"(just short of 9mm...) but @ 28" of water... 190cfm @ 20" is quite high, although not directly correlate-able, the numbers @ 28" would be/should be around 266 @ 28". My 16V work tends to get a tick over 200 cfm @ 9mm and 28" Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-17-2015, 03:30 AM
When I see your numbers then I know there must be something wrong with my builders measurements. No way my 16v is flowing this much. Maybe it is with flowbenches as with dynoes - all you can really use is the delta.
09-17-2015, 06:15 PM
(This post was last modified: 09-17-2015 06:17 PM by oldeskewltoy.)
(09-17-2015 03:30 AM)harkes Wrote: When I see your numbers then I know there must be something wrong with my builders measurements. No way my 16v is flowing this much. Maybe it is with flowbenches as with dynoes - all you can really use is the delta.can't speak to your guys bench... but just looking at my stuff, I'm at 186 @ .350" lift @ 25"... so instead of 20, maybe he measured @ 25???? 20" does seem an unusual # to measure from....... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-18-2015, 05:05 AM
Can it really be the true that a stock head flow less @ 9mm than 8mm?
09-18-2015, 09:05 AM
highly unlikely, usually they just plateau i.e. no more useful gains. If you search google for flowbench and 4age you should come across a few other measurements incl. some from Orion (unfortuantely the original uploads aren't accessible anymore)
AE86 ex-daily |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,446 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,606 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,179 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,057 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,624 |
