OST-064: Breathing on a 3 rib
03-25-2020, 05:19 PM (This post was last modified: 03-25-2020 05:21 PM by oldeskewltoy.)
oldeskewltoy Wrote:along with assembled short block - those are Molnar Tech 40/20 H- beam rods
[Image: AEU86 AE86 - OST-064: Breathing on a 3 rib]
More to come..... Big Grin
Did(Do) you see it????
How about if I point it out.......
A little extra clearance at the bottom of the bores to make sure the new rods clear during rotation
As often happens when you mix valves from one head, with a different head... and new cams......
Getting the valves tipped so that they are in the middle of my shim bank sizes so I can set valve clearance to the thousandth(.001")
more to come...... Hurray!
Dan -
03-26-2020, 07:54 PM (This post was last modified: 03-26-2020 07:54 PM by oldeskewltoy.)
a nice 3 angle valve job... and back cut intake valve......
more to come... Hurray!
Dan -
04-02-2020, 04:39 PM
fresh hone....
and with the Cometic gasket fitted... NOTE: the front, and rear placement for the oil feed(front), and oil drain (rear)
and with the head fitted
more to come.... Hurray!
Dan -
04-03-2020, 11:59 PM
A step further....
Doing a bit of custom fitting... the stock lower timing cover will not accommodate the T3 pulley snout (its broader - more diameter than stock), so the lower timing cover is "adjusted" so it will accommodate the T3 pulley
Once that detail is taken care of, the rest of assembly goes smoothly
Dan -
04-06-2020, 08:11 AM
Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk?
04-06-2020, 05:37 PM
(04-06-2020 08:11 AM)Ivan141 Wrote:  Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk?
NOT a fan.... and with the current exchange rate (to USA) there is no reason not to run a Ross. MRP has them for $560 NZD, or about $360 USD
My engine... I'm running a modified OEM pulley
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,336 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,341 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,037 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 1,944 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,534 06-28-2022 09:17 PM
