OST-064: Breathing on a 3 rib
03-25-2020, 05:19 PM
(This post was last modified: 03-25-2020 05:21 PM by oldeskewltoy.)
oldeskewltoy Wrote:along with assembled short block - those are Molnar Tech 40/20 H- beam rods Did(Do) you see it???? How about if I point it out....... ![]() A little extra clearance at the bottom of the bores to make sure the new rods clear during rotation As often happens when you mix valves from one head, with a different head... and new cams...... ![]() Getting the valves tipped so that they are in the middle of my shim bank sizes so I can set valve clearance to the thousandth(.001") more to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2020, 07:54 PM
(This post was last modified: 03-26-2020 07:54 PM by oldeskewltoy.)
a nice 3 angle valve job... and back cut intake valve......
![]() more to come... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-02-2020, 04:39 PM
fresh hone....
![]() and with the Cometic gasket fitted... NOTE: the front, and rear placement for the oil feed(front), and oil drain (rear) ![]() and with the head fitted ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-03-2020, 11:59 PM
A step further....
![]() Doing a bit of custom fitting... the stock lower timing cover will not accommodate the T3 pulley snout (its broader - more diameter than stock), so the lower timing cover is "adjusted" so it will accommodate the T3 pulley ![]() ![]() Once that detail is taken care of, the rest of assembly goes smoothly ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-06-2020, 08:11 AM
Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk?
04-06-2020, 05:37 PM
(04-06-2020 08:11 AM)Ivan141 Wrote: Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk? NOT a fan.... and with the current exchange rate (to USA) there is no reason not to run a Ross. MRP has them for $560 NZD, or about $360 USD My engine... I'm running a modified OEM pulley ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,554 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,923 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,364 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 2,160 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,717 |
