OST-064: Breathing on a 3 rib
03-25-2020, 05:19 PM
(This post was last modified: 03-25-2020 05:21 PM by oldeskewltoy.)
oldeskewltoy Wrote:along with assembled short block - those are Molnar Tech 40/20 H- beam rods Did(Do) you see it???? How about if I point it out....... A little extra clearance at the bottom of the bores to make sure the new rods clear during rotation As often happens when you mix valves from one head, with a different head... and new cams...... Getting the valves tipped so that they are in the middle of my shim bank sizes so I can set valve clearance to the thousandth(.001") more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2020, 07:54 PM
(This post was last modified: 03-26-2020 07:54 PM by oldeskewltoy.)
a nice 3 angle valve job... and back cut intake valve......
more to come... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-02-2020, 04:39 PM
fresh hone....
and with the Cometic gasket fitted... NOTE: the front, and rear placement for the oil feed(front), and oil drain (rear) and with the head fitted more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-03-2020, 11:59 PM
A step further....
Doing a bit of custom fitting... the stock lower timing cover will not accommodate the T3 pulley snout (its broader - more diameter than stock), so the lower timing cover is "adjusted" so it will accommodate the T3 pulley Once that detail is taken care of, the rest of assembly goes smoothly Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-06-2020, 08:11 AM
Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk?
04-06-2020, 05:37 PM
(04-06-2020 08:11 AM)Ivan141 Wrote: Dan, I'm curious what your view is on these pulleys.. is the lack of harmonic balancing not a risk? NOT a fan.... and with the current exchange rate (to USA) there is no reason not to run a Ross. MRP has them for $560 NZD, or about $360 USD My engine... I'm running a modified OEM pulley Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,328 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,322 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,033 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,938 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,530 |
