OST-070: 7AGE for an N2 Levin
08-07-2020, 06:06 PM
[Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]
Back in February I was contacted to build an engine for an N2 Levin replica being built in America. The client was not looking for all out power, but they did want a big valve 7AGE.
more to come....... Big Grin
Dan -
08-09-2020, 10:22 PM
So then the owner will retain the stock internals of the 7AGE? Or will you replace it with something else instead? Dumb question
08-10-2020, 06:26 PM
(08-09-2020 10:22 PM)banpei Wrote:  So then the owner will retain the stock internals of the 7AGE? Or will you replace it with something else instead? Dumb question
Actually this will be a fair bit higher end then that. OST-070 will be running Saenz Rods, OST designed pistons, Ferrea valves, Cat cams 9mm lift cams, and Tec-Arts ITB system. It will remain a wet sump, and the cams duration should peak @ about 8000-8100
from another forum Wrote:I suspect a lot of work going into the head for this one. Big cams and valves. Replacement of the valve seats to accommodate the new valves?
This head will be similar to OST-043, so yes... a great deal of work - beginning with new valve seats.
more to come.... Hurray!
Dan -
08-10-2020, 09:13 PM
Nice! Thumbs up!
And what about the crank shaft? Will that be MRP or 2ZZ?
08-10-2020, 11:49 PM
(08-10-2020 09:13 PM)banpei Wrote:  Nice! Thumbs up!
to remain 7A...
Dan -
08-11-2020, 04:26 PM
OST Wrote:Back in February I was contacted to build an engine for an N2 Levin replica being built in America. The client was not looking for all out power, but they did want a big valve 7AGE.
About a week ago this arrived.....
.... and once opened....
... and once unpacked...
the 4A oil pan was used to make shipping a bit easier
more to come...... Hurray!
Dan -
08-11-2020, 09:48 PM
Looking forward to this build, please post as many details as possible, also about the block assembly, would be nice to have a good build tread about a 7AGE, as I am going to build one for my car Dodgy
Will you be using a 4AGE Oil pump?
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
08-13-2020, 08:48 PM
(08-11-2020 09:48 PM)Vaptor Wrote:  Looking forward to this build, please post as many details as possible, also about the block assembly, would be nice to have a good build tread about a 7AGE, as I am going to build one for my car Dodgy
yes... with a few minor modifications (more later)
Some of the parts..... from around the world......
Ferrea Atlantic valves (USA)
Tec-Arts ITB adapter/kit..... (Japan)
.... and their 7A cooling system adapter
MRP supplied the timing kit... (New Zealand)
as well as the Saenz rods... (on a familiar cart Wink ) (USA)
Also using MRP's oil pan.
And for the first time, I'll be using Flo's engine bolt kit (Ireland)
I'll also be using Cat Cams 262/230 9.0mm lift cams, Toda valve springs, and viton rubber valve seals.
Dan -
08-14-2020, 10:57 PM
That's truly a world wide build! Respect!
I'm really looking forward seeing this advance!
08-15-2020, 10:49 PM
What is the advantage of the MRP's wet sump, compared to a normal AE86 sump?
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,692 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 7,471 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,063 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,304 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,689 06-28-2022 09:17 PM
