OST-070: 7AGE for an N2 Levin
08-07-2020, 06:06 PM
Back in February I was contacted to build an engine for an N2 Levin replica being built in America. The client was not looking for all out power, but they did want a big valve 7AGE. more to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-09-2020, 10:22 PM
So then the owner will retain the stock internals of the 7AGE? Or will you replace it with something else instead?
08-10-2020, 06:26 PM
(08-09-2020 10:22 PM)banpei Wrote: So then the owner will retain the stock internals of the 7AGE? Or will you replace it with something else instead? Actually this will be a fair bit higher end then that. OST-070 will be running Saenz Rods, OST designed pistons, Ferrea valves, Cat cams 9mm lift cams, and Tec-Arts ITB system. It will remain a wet sump, and the cams duration should peak @ about 8000-8100 from another forum Wrote:I suspect a lot of work going into the head for this one. Big cams and valves. Replacement of the valve seats to accommodate the new valves? This head will be similar to OST-043, so yes... a great deal of work - beginning with new valve seats. more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-10-2020, 09:13 PM
Nice!
And what about the crank shaft? Will that be MRP or 2ZZ? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-10-2020, 11:49 PM
(08-10-2020 09:13 PM)banpei Wrote: Nice! to remain 7A... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-11-2020, 04:26 PM
OST Wrote:Back in February I was contacted to build an engine for an N2 Levin replica being built in America. The client was not looking for all out power, but they did want a big valve 7AGE. About a week ago this arrived..... .... and once opened.... ... and once unpacked... the 4A oil pan was used to make shipping a bit easier more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-11-2020, 09:48 PM
Looking forward to this build, please post as many details as possible, also about the block assembly, would be nice to have a good build tread about a 7AGE, as I am going to build one for my car
Will you be using a 4AGE Oil pump? Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
08-13-2020, 08:48 PM
(08-11-2020 09:48 PM)Vaptor Wrote: Looking forward to this build, please post as many details as possible, also about the block assembly, would be nice to have a good build tread about a 7AGE, as I am going to build one for my car yes... with a few minor modifications (more later) Some of the parts..... from around the world...... Ferrea Atlantic valves (USA) Tec-Arts ITB adapter/kit..... (Japan) .... and their 7A cooling system adapter MRP supplied the timing kit... (New Zealand) as well as the Saenz rods... (on a familiar cart ) (USA) Also using MRP's oil pan. And for the first time, I'll be using Flo's engine bolt kit (Ireland) I'll also be using Cat Cams 262/230 9.0mm lift cams, Toda valve springs, and viton rubber valve seals. more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-14-2020, 10:57 PM
That's truly a world wide build!
I'm really looking forward seeing this advance! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-15-2020, 10:49 PM
What is the advantage of the MRP's wet sump, compared to a normal AE86 sump?
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 2,305 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 4,246 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,011 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,922 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,522 |
