Objective, 200hp with 4age.
12-16-2011, 10:05 PM
for injectors you could use some supra MK3 non turbo.. (7MGE)
they ar 312cc; high impendance (good for stand alone) and straigt fit on bigport fuel system and a question from my side... what is the big difference between 40mm or 42mm crank ? do these 2mm add so much strength? or is that because there no good rods available for de 40mm crank ? '87 levin coupé |
12-16-2011, 10:18 PM
I'm not engine builder, pretty much amateur, but what i've seen ITB's are a must for high end 4AGE. Plenum/airbox or not, your choice, but must have 4 blades.
Worth considering is two stage injection. In total, ~350cc injector per cylinder will be enough even for 10 000 rpm and AFR below 12. |
12-16-2011, 11:55 PM
speakin about rpm and etc
engines can go up in rpm bat to have power so hi up you need cams over 300 . cams below 300 like the 288 i consider them for daily drive . when you speak for race motor we always put cams more then 300. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
12-17-2011, 12:00 AM
also the superteck parts are the worst you can install in your motor .
my personal opinion . not so good company . for good usa try ferrea. one of the best . or toda or trd or some other japanese brand. many times happen to us that supertech valves broke at the neck . best that i try was the ferrea. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
12-17-2011, 12:44 AM
Uzelac Wrote:15:1 compression ?!?!?! Aviation fuel... |
12-17-2011, 12:46 AM
Project D Wrote:4000GT Wrote:15:1 compressionYou mean 15 bar ? (wich should be around 13:1 CR) Nope I mean 15:1 static compression. With big cams the compression does bleed off, dynamic compression... There is more timing that could be wound in with ethanol, which I may tune up on down the track. |
12-17-2011, 12:51 AM
PatrickAE86 Wrote:and a question from my side... Well the biggest difference is the crank itself. Since it isn't full counter(which generates a greater imbalance at high RPM), it is weaker than the 42mm (almost full counter) Sadly their is no compagny who make forged full counter crank in 40mm + Forged conrod. (recently +EM have made conrods in 40/20) On the other hand many compagny like Tomei, Tec Art's, Jun etc. offer full counter crank in 42mm and conrod. |
12-17-2011, 03:44 AM
NoHachi Wrote:Can everyone also add a cost estimate and the number of KM's or Miles between rebuilds? I'm particularly interested in the latter.3 oil changes, 5500 miles so far...no rebuilds... don't expect any. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-17-2011, 05:38 AM
I have done 3 race meetings so far, still in one piece, its how life is spent in the 6-9k range.
12-17-2011, 01:51 PM
oldeskewltoy Wrote:NoHachi Wrote:Can everyone also add a cost estimate and the number of KM's or Miles between rebuilds? I'm particularly interested in the latter.3 oil changes, 5500 miles so far...no rebuilds... don't expect any. Not your daily beater, exquisite as it is, the Initial D 200hp9000rpm for the OP. So what! |
DIV 1 rally/track 4AGE(objective +- 130 whp) | ditn | 39 | 37,710 |
01-03-2012 09:07 AM Last Post: Bean |
Discussion: blacktop 20v: the road beyond 200HP | 86er | 19 | 22,756 |
02-21-2007 07:06 AM Last Post: BenR |
Discussion: blacktop 20v: the road beyond 200HP | 86er | 1 | 6,656 |
01-17-2007 06:25 PM Last Post: 86er |
