Objective, 200hp with 4age.
12-16-2011, 10:05 PM
for injectors you could use some supra MK3 non turbo.. (7MGE)
they ar 312cc; high impendance (good for stand alone) and straigt fit on bigport fuel system Smile
and a question from my side...
what is the big difference between 40mm or 42mm crank ? do these 2mm add so much strength?
or is that because there no good rods available for de 40mm crank ?
'87 levin coupé
[Image: AEU86 AE86 - Objective, 200hp with 4age.]
12-16-2011, 10:18 PM
I'm not engine builder, pretty much amateur, but what i've seen ITB's are a must for high end 4AGE. Plenum/airbox or not, your choice, but must have 4 blades.
Worth considering is two stage injection.
In total, ~350cc injector per cylinder will be enough even for 10 000 rpm and AFR below 12.
12-16-2011, 11:55 PM
speakin about rpm and etc
engines can go up in rpm bat to have power so hi up you need cams over 300 .
cams below 300 like the 288 i consider them for daily drive .
when you speak for race motor we always put cams more then 300.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
12-17-2011, 12:00 AM
also the superteck parts are the worst you can install in your motor .
my personal opinion .
not so good company .
for good usa
try ferrea.
one of the best .
or toda or trd or some other japanese brand.
many times happen to us that supertech valves broke at the neck .
best that i try was the ferrea.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
12-17-2011, 12:44 AM
Uzelac Wrote:15:1 compression ?!?!?! Big Grin
What fuel do you use ?
Aviation fuel...
12-17-2011, 12:46 AM
Project D Wrote:
4000GT Wrote:15:1 compression
You mean 15 bar ? (wich should be around 13:1 CR)
15:1 static CR wit 288° cams, even with race fuel and retarded ignition, the only thing you will obtain is massive pre-ignition or detonation ...
(Even atlantic engine won't run so high CR)
For 200hp you have to use OS valve -> a complete kit cost around 1000€
You should also consider the machining (who cost a lot too)
(I'm currently building a 4AG for 190 / 200 hp)
Nope I mean 15:1 static compression.
With big cams the compression does bleed off, dynamic compression...
There is more timing that could be wound in with ethanol, which I may tune up on down the track.
12-17-2011, 12:51 AM
PatrickAE86 Wrote:and a question from my side...
Well the biggest difference is the crank itself.
Since it isn't full counter(which generates a greater imbalance at high RPM), it is weaker than the 42mm (almost full counter)
Sadly their is no compagny who make forged full counter crank in 40mm + Forged conrod. (recently +EM have made conrods in 40/20)
On the other hand many compagny like Tomei, Tec Art's, Jun etc. offer full counter crank in 42mm and conrod.
12-17-2011, 03:44 AM
NoHachi Wrote:Can everyone also add a cost estimate and the number of KM's or Miles between rebuilds? I'm particularly interested in the latter.
3 oil changes, 5500 miles so far...no rebuilds... don't expect any.
Dan -
12-17-2011, 05:38 AM
I have done 3 race meetings so far, still in one piece, its how life is spent in the 6-9k range.
12-17-2011, 01:51 PM
Not your daily beater, exquisite as it is, the Initial D 200hp9000rpm for the OP.
Wink Wink
So what!
  DIV 1 rally/track 4AGE(objective +- 130 whp) ditn 39 37,514 01-03-2012 09:07 AM
  Discussion: blacktop 20v: the road beyond 200HP 86er 19 22,742 02-21-2007 07:06 AM
Last Post: BenR
  Discussion: blacktop 20v: the road beyond 200HP 86er 1 6,653 01-17-2007 06:25 PM
Last Post: 86er
