Oil Pan connection
04-30-2013, 10:52 PM
Oil Pan connection
I have recently bought a brand new oil pan.
Am unsure of the adaptor / connection I need for the oil cooler pipes to screw onto? Any ideas? |
05-01-2013, 05:26 AM
Oil Pan connection
If you want to keep it standard, you need a banjo bolt, cant remember the thread at the moment...
05-01-2013, 12:01 PM
Oil Pan connection
Yeah i'm going to reuse the oil cooler that i've got bolted to the bulkhead of my mr2.
Haven't been able to use it since I switched to the AE92 engine as sump didn't come with outlet. |
| Oil Pan Issue | Alex170984 | 6 | 8,439 |
01-11-2016 04:50 PM Last Post: Alex170984 |
| Correct connection brake master cylinder? | bozu | 5 | 8,847 |
| trans oil, lsd oil change | Apolan | 9 | 20,107 |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 36,206 |
| 4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 9,587 |
