Oil Pan connection
04-30-2013, 10:52 PM
Oil Pan connection
I have recently bought a brand new oil pan.
Am unsure of the adaptor / connection I need for the oil cooler pipes to screw onto?
Any ideas?
05-01-2013, 05:26 AM
Oil Pan connection
If you want to keep it standard, you need a banjo bolt, cant remember the thread at the moment...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-01-2013, 12:01 PM
Oil Pan connection
Yeah i'm going to reuse the oil cooler that i've got bolted to the bulkhead of my mr2.
Haven't been able to use it since I switched to the AE92 engine as sump didn't come with outlet.
  Oil Pan Issue Alex170984 6 7,162 01-11-2016 04:50 PM
Last Post: Alex170984
  Correct connection brake master cylinder? bozu 5 7,618 07-26-2015 12:28 PM
Last Post: bozu
  trans oil, lsd oil change Apolan 9 17,644 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,901 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 8,159 10-01-2011 09:47 AM
Last Post: demogun
