Old Fashioned
05-11-2005, 09:28 AM
Post: #91
Old Fashioned
the previous owner said there were none, just the carpet?? liar!
2Kas: i have had shit with those, but i have managed to put them on thisway. Didnt have the energy to cut all the straps i have used tu put on my bumper. (no screws and that..) Have i mentioned, that i have ordered a new Nissens radiator for some 120 eur. Its new! Original costs here around 400 eur!!! |
05-13-2005, 08:43 AM
Post: #92
Old Fashioned
I have discovered that i am one radiator and vent housing short. yes i am missing the plastic frame supporting the rad and vent. is there anybody who has one spare? please, i need it badly.
lp! |
05-13-2005, 10:27 AM
Post: #93
Old Fashioned
Which is this housing? Do you have a photo?
If you mean the plastic housing between radiator & ventilator you don't need it. The shroud 16712 in the drawing is not applicable for my car... http://www.mobisux.com/album/data/500/8196shroud.JPG Andrej |
05-13-2005, 03:01 PM
Post: #94
Old Fashioned
i need both! 16712 and 16701.. (zoran je reku da ga nima doa, ampak da je pa blo..) How do you mean i dont need it? I would like to have it.. how else can i bolt the radiator into the bay?
05-13-2005, 03:09 PM
Post: #95
Old Fashioned
Apolan Wrote:i need both! 16712 and 16701.. (zoran je reku da ga nima doa, ampak da je pa blo..) How do you mean i dont need it? I would like to have it.. how else can i bolt the radiator into the bay?The radiator uses 2 stands (pins) downside and 2 plates on top - to fix it in the bay. This is the VAZ radiator in AE86 bay but you can see clearly the top plates. |
05-13-2005, 10:45 PM
Post: #96
Old Fashioned
Apolan, if I write my vin in EPC, and search for radiator I find the picture I posted.
Then I click on the part 16712 to see it's part number and epc says "not applicable". I don't have it; the same was with catalytic converter for e.g. So my model didn't came with that part. If you see explanation 1, 2, 3, and 4 on the picture: #1 means, that the shroud is applicable for cars with cooler (I think cooler in this case means air condition system)... Andrej |
05-16-2005, 09:18 AM
Post: #97
Old Fashioned
but zoran said that there was one, but he somehow lost it i asume.. nevermind, if its okay w/o, then there will be none.. no sticking fingers in the engine bay when the engine's hot. =)
can somebody please explain how does teh lamel-type fan work? |
05-16-2005, 03:21 PM
Post: #98
Old Fashioned
Quote:can somebody please explain how does teh lamel-type fan work? You mean - stock AE86 fan ? There is a silicone "clutch" in the aluminium body. The alternator belt powers water pump also and when this "silicone clutch" works (i.e. when the temperature in engine bay raises) - the fan works also. Thanks God - because when my car crashed - the original water radiator was folded over the fan but I still have good water pump... |
05-19-2005, 08:43 AM
Post: #99
Old Fashioned
So its like a temperature-triggered LSF (f-fan) =)
06-01-2005, 08:43 AM
Post: #100
Old Fashioned
HUGE UPDATE
the engine fired for the first time in 7 or 8 years! its amazing, i just love toyota. wired it up and started, it fired in a second! after 8 years sitting in a garage! tnx to croatian hachi friends (kas, hrc, zax, bitumen?) who let me copy all the wireing from their hachis.. for the first time i have seen another hachi. =) anwayz the engine seems to run nice and smooth, though its a bit loud since i have only fitted the headers yet. revving her up to some 3000 rpm seems very lively (and very loud - fire bangs on lift-off =)). so not very far from the happy end now.. just have to get front shocks fixed and some othe little things.. im sooo happy! |
danish renovation, from rusty old banger, to nice drift car | katapouser | 15 | 16,928 |
12-23-2008 10:41 PM Last Post: katapouser |
Cp joels old school drifter (56k warning) | cp joel | 77 | 62,518 |
09-17-2005 01:21 PM Last Post: James |
Jons New [Old Project] | JonT | 75 | 57,947 |
08-08-2005 04:26 PM Last Post: Blueneon |
