One-piece driveshaft
12-26-2009, 11:20 AM
I've got a drive shaft from Max. It vibrated like hell untill I got it balanced. After this its ok. I don't think there is a lot to gain though...
12-27-2009, 06:24 AM
Jan Pedersen Wrote:I've got a drive shaft from Max. It vibrated like hell untill I got it balanced. Factory driveshafts are balanced, and any custom or modified driveshaft needs to be balanced. That is just a simple out of balance rather than a torsional vibration, and easily fixed. Given that driveshafts are basically a thin wall tube, the change in inertia between one-piece and two-piece will be quite small. As you say, the effect will be hard to measure, and easily surpassed by the effect of larger wheels or heavier tires. One of the things that interests me, is that the one-piece driveshaft will be putting higher loads on the gearbox output shaft bearings. I'm wondering if anyone has ever found that the gearbox needed more attention after fitting a one-piece shaft ?? Cheers... jondee86 |
02-23-2010, 07:20 PM
I recently installed the onepiece shaft with a rebuild rearaxle and a 2way diff. I have no a very highpitched singing noise, comming from the valve train. The Differential was aligned by my mechanic who has the knowhow doing that properly.
What do you think? Does the noise come from a bad balanced driveshaft? Cheers! |
02-23-2010, 11:14 PM
Jan Pedersen Wrote:I've got a drive shaft from Max. It vibrated like hell untill I got it balanced. After this its ok. I don't think there is a lot to gain though... how do you go about doing this?? |
02-23-2010, 11:33 PM
You bring it to a company that specializes in balancing. Let us know how things go. My money is still on the pignion.
02-24-2010, 10:07 PM
MartinS Wrote:I have now a very highpitched singing noise, comming from the valve train.If by valve train you refer to the top of the engine, it is most unlikely that the cause is in the rear end or driveshaft. Rear end noise can sound like wheel bearings or gearbox noise, but I have never heard it coming from the engine. I suggest you get a short length of garden hose and with one end to your ear, probe the other end around the running engine. You could have a vacuum leak. Does the noise follow engine speed or road speed ?? Cheers... jondee86 |
02-24-2010, 10:18 PM
sorry, I was stoned or what ever. But the noise is coming from the pinion and crown wheel or the finalgear assembly. And is in relation to speed.
03-01-2010, 06:10 PM
Simplest thing is to replace your original 2-piece axle. Quick and easy to do and allows you to eliminate the driveshaft as a cause.
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 6,861 |
07-28-2022 10:48 PM Last Post: banpei |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,291 |
Driveshaft free play | thanos | 6 | 9,471 |
02-25-2015 02:10 AM Last Post: thanos |
Driveshaft question | DidiDex | 3 | 5,437 |
02-12-2015 09:43 AM Last Post: DidiDex |
anyone produce new harness for bluetop?gts driveshaft | dinkers542 | 8 | 8,145 |
11-25-2014 09:18 PM Last Post: dinkers542 |
