Peculiar headlight issue - main beam
10-03-2015, 01:45 PM (This post was last modified: 10-03-2015 01:46 PM by Jezza_hr.)
I seem to have a ververy strange issue. I'm currently running HID lights that have stopped working on main beam. I can hear clicking in the unit but the lights don't change, the main beam indicator doesn't come on on the dash and the lights do flash, so long as the lights aren't on.
Assuming the issue could be with the stalk, I used a spare and there was no change. So my next thought was it could be the control box for the HIDs. I disconnected the HIDs and plugged in my standard bulbs and they only work on main beam and not dipped, so the problem is reversed and the beam indicator light appears on the dash.
My only conclusion right now is the problem could be in the main headlight switch, but I wanted to ask here and see if anyone else had any ideas?
10-04-2015, 03:08 AM
Sure, it could be the headlight switch, but waaay more likely that it's something that you've done or added, a bad wire terminal/connection/crimp or relay.
So what!
10-04-2015, 10:56 AM
I wouldn't have thought it would be something I've added, since when I disconnect the HIDs and connect the standard bulbs, I'm left with standard wiring and have cut out any aftermarket stuff.
10-04-2015, 09:25 PM
Issue has been resolved. Seemed it was two separate issues for both the HIDs and the stalk. Strangely though, the first time I tested the stalk the problem didn't change, testing it a second time it resolved itself. But it seems I need to get a new HID relay though.
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 1,705 04-26-2025 03:24 PM
Last Post: DaLanZhu
  High-beam warning lamp Mylesmck 4 3,114 07-21-2023 07:44 AM
  PWR light issue and no brake fluid after winter storage magpie 10 5,640 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 8,386 04-29-2022 05:45 AM
  Clutch Issue Deaty 8 6,196 04-09-2021 10:26 PM
Last Post: Nakilad
