Performance exhaust manifold?
10-03-2005, 01:04 PM
Ivan141 Wrote:Only 20V 4age's have different exhaust ports.
Are you sure that 16V and 20V ex ports are different ?
10-03-2005, 01:19 PM
Yes...but there is not very much difference since people sometimes adjust 16v manifolds to fit on 20v heads. Maybe just the bolt pattern.
10-03-2005, 04:51 PM
The 16v manifolds work on 20v heads without a problem. The only thing is that the 20v bolts don't always cover with 16v's holes, so the manifold needs to be trimmed.
Taken from club4ag.com forums:
[6.) Your still probably stuck aren't you? You cannot figure out how you can properly bolt on your factory headers. Upon matching up the original headers to your 20 Valve motor you will notice that the two end bolts of the header do not align up with the bolt holes on the new motor. Anyway, easy fix...take out your hacksaw and cut away the end of your header. You will not need to cut off much, just enough that you can clearly see the bolt holes located in the head of the engine. About half of the bolt hole on the header is enough to be cut off. Once you've cut off the ends of the header, you should be able to reuse the supplied 20 Valve bolts that have washers and bolt on the header with no problems.
[Image: AEU86 AE86 - Performance exhaust manifold?]
10-03-2005, 04:58 PM
I dont care about 20V Big Grin
What about the 4agZe, thats a 16v engine
[Image: AEU86 AE86 - Performance exhaust manifold?] http://www.jdmbits.com
10-03-2005, 06:38 PM
Factory manifold should bolt up without problems. I've heard of people using TRD headers in both big- and smallport engines, and that includes GZE's.
10-04-2005, 11:04 PM
Alex Hom's e-mail is .... [email protected]
10-04-2005, 11:55 PM
tnx Smile
Andrej
  Smallport inlet manifold totta Crolla 6 3,551 01-17-2022 05:14 PM
  weir performance email filh 2 4,873 06-14-2015 05:37 PM
  4age blue top from MR2 same intake manifold? dinkers542 8 10,763 11-02-2014 05:24 PM
Last Post: ditn
  4AGTE turbo manifold questions daveskatesallday 3 5,071 08-13-2013 07:38 PM
Last Post: daveskatesallday
  Weir Performance rear upgrade kit for AE86 heshan 5 9,298 07-22-2013 09:11 PM
Last Post: heshan
