Problem with brakes
03-23-2006, 09:18 AM
Problem with brakes
I have a strange problem with brakes. Front right brake has 40-50 % less braking power then the left one (tested last week). Also, the brake pedal has a soft feeling. Rear brakes and handbrake are working perfectly. Front left brake is also working great. So far I’ve tried to bleed the air out several times and I've noticed no change at all.
What to do next?
thx
Fun is not the straight line!
03-23-2006, 09:47 AM
Problem with brakes
Check the whole right front brake assembly. So inspect lines for leaks, test the callipers manually for good operation, check pad position etc etc.
03-27-2006, 08:25 AM
Problem with brakes
Problem solved!!!
I’ve checked the right calipers and find out that slider on the right one has been jammed. After little cleaning and putting new grease, replacing the front pads, everything is working fine now.
Hurray!
  Rear brakes totta Crolla 0 916 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 2,622 07-08-2022 03:35 AM
Last Post: trippin
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,771 12-21-2016 09:37 PM
Last Post: bozu
  Hydraulic handbrake with stock rear brakes Dino86 11 15,386 07-11-2014 08:33 PM
Last Post: Dino86
  S13 Front brakes in AE86 rear heshan 25 28,162 02-01-2014 12:37 PM
Last Post: heshan
