Removing front window trim
09-06-2014, 03:41 PM
(This post was last modified: 09-06-2014 03:41 PM by zenki.)
Anyone know how to safely remove the front window trim? The trim from the side windows was easy to remove but the front won't move. I'm afraid i'm going to break them or even worse crack my windshield.
ハチロク ![]() |
09-06-2014, 04:44 PM
Check the manual it's described there in detail
AE86 Levin |
09-06-2014, 10:35 PM
I used small guitar strings to cut the kit for front window. Only you need be careful as the string will getting hot.
09-06-2014, 11:44 PM
Here you go...follow instructions carefully and you should succeed just fine.
09-07-2014, 12:12 AM
^^I looked at the manual and didn't see those pages, guess i missed them.
I'm not good with these fiddly jobs but they have to come off cause the car is getting 2k primered pretty soon. ハチロク ![]() |
09-07-2014, 03:57 PM
Just follow the instructions carefully and the trim should come off just fine. If I managed, so can you.
You definitely don't want to rush anything and break one of these parts because they are hard to come by. FABRICA MI DIEM, PVNC! |
09-07-2014, 07:57 PM
They're already off. The sideparts were attached with 3 screws each. Pulled the rubber seal away and that revealed screws. When the sides were off the top part could slide off. Alot of the clips for the top part were already broken. Atleast i got the trims off without breaking.
ハチロク ![]() |
09-07-2014, 08:36 PM
The clips are not a problem, those can be found.. the trim is notoriously hard to find.. dunno if Toyota still has it in stock, probably not.
window winder mechanism | kazi | 4 | 5,191 |
05-23-2018 11:00 PM Last Post: kazi |
removing light switch ? (fixed) | MC_JP | 10 | 17,461 |
09-18-2014 05:16 PM Last Post: MC_JP |
rear window defroster lines | zenki | 3 | 5,586 |
11-15-2013 02:58 PM Last Post: Ivan141 |
Removing interior plastics | Jezza_hr | 3 | 5,687 |
03-18-2013 11:41 PM Last Post: Ivan141 |
Trim levels? | Serencebey | 17 | 24,417 |
11-20-2012 09:24 PM Last Post: banpei |
