Questions about TRD 2 Way LSD and 4.7 Final Gear...
10-13-2006, 08:29 PM
Hi everyone !
In 3 weeks I will install a 4.7 final gear and a TRD 2 way LSD on my Hachi. I have several questions : - Is the TRD LSD noisy ? I have read that 2 way LSD are noisy , but some persons says that if it is installed correctly , it isn't making noise. - Is the 4.7 final gear bolt on ? My Hachi is a zenki model. Thank you very much !! ( Sorry for my english ^^ ) |
10-13-2006, 10:45 PM
The final gears are all the same for GT ae86's.. (not sr5's), so that will fit, dont know if the term bolt-on quite covers the work involved.
Most aftermarket LSD's make a little chattering noise when cornering, but this gets less evident when they are worn in.. This is not the same noise you get when you install it incorrectly, cause that would be noise coming from your final gearset and not the lsd itself. FABRICA MI DIEM, PVNC! |
10-13-2006, 10:49 PM
Ivan is there a topic for final gear DIY correct installation instructions ????
AE86 FANATIC!!! |
10-13-2006, 10:54 PM
we have made some attempts in the past... look for ring AND pinion in the search, I'm sure something will pop up. For the rest I would say that the factory manual and all necessary tools are the bare minimum of what you need to get it done right.
10-13-2006, 11:57 PM
THANKS MY FRIEND !!!
AE86 FANATIC!!! |
10-14-2006, 10:27 AM
also recall the trd 2 way being the most quiet of the after market ones?
10-14-2006, 11:26 AM
Who cares about the noise, it's not like the ae86 is a particularly quiet car (in bog standard form it's already too loud to drivce comfortably).
You'd just be adding another sound..and when people ask you can tell them that's just the TRD lsd doing it's job. FABRICA MI DIEM, PVNC! |
10-14-2006, 12:19 PM
Oki ! Thank you very much !
Actually , my stock ring and pinion make a horrible noise when I accelerate. I was just scared that the 2 way LSD makes more noise ^^ |
10-14-2006, 12:43 PM
the TRD 2 way is fairly quiet.I have one in my car
however it is not a job I would do my self send it to a gearbox place to get built. as it aint an easy job, and requires a few special tools |
11-09-2006, 10:57 PM
Hi !
My father have installed the LSD and the Final Gear last monday on my Hatchi...And I like it ! No more noise ! The TRD LSD is realy quiet ! |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,455 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 1,242 |
04-30-2024 09:46 PM Last Post: Mylesmck |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,403 |
05-10-2021 01:02 PM Last Post: Project D |
5th gear issue | r.ave | 1 | 2,631 |
03-14-2021 08:52 PM Last Post: Ivan141 |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,681 |
05-17-2019 09:08 AM Last Post: Ivan141 |
