RX7 brake adaptor brackets -
08-26-2008, 03:04 PM
Does anyone know where I can get hold of the files for the brackets that Hen has so kindly developed.
Speaking to a chap who will potentially be able to make a set for me but he would like the cad files (already supplied him the available diagrams etc) If anyone can help that would be greatly appreciated. Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
08-27-2008, 05:30 AM
Many people say that the surface area of the picton of the AE86 is just as large as the twin pistons of the FC3S.
08-27-2008, 10:35 AM
Rx7 caliper is 4 piston - and also alloy so despite their size they are quite a bit lighter than the small stock cast caliper.
08-27-2008, 12:59 PM
Why is it bad that the piston area is the same as the original caliper?
You have to balance changing of piston area with disc size to get the brake balance you want (ignoring bias adjustment via balance bar or pressure regulator). If you want to keep the same rear brakes and fit larger front discs then you should reduce the front piston area. If you want to increase the front and rear disc sizes you might want to keep the piston area of the front caliper the same. The RX7 4 pots are alloy so are lighter and also you should get better brake feel (they should be stiffer but don't assume an alloy 4 ot is automatically stiffer as aluminium is not as stiff are steel) and pad wear will be more even/reduced. |
08-27-2008, 02:48 PM
So with all that said .. does anyone have the cad file or know where I can get it?
Someone must have the file handy? ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
09-01-2008, 06:15 AM
PM me your email addy and I'll send you a zip file. These brackets are designed to fit a 2001 mini cooper S disk.
Search for Oly or Blue86 (?) on ae86drivingclub for his write up. regards, Chris |
09-01-2008, 11:18 PM
Just contact Aussiefan on this forum , I think he does a good job on this !
fil Filh Save the RWD cars |
09-08-2008, 01:15 PM
Chrisso, thanks for the offer - Aussie Fan kindly hooked me up.
Need to see if I can buy these now as the machine shop I was intending on using have said they dont think they can make them. Hopefully Aussie Fan has a spare set.
| sharing knowledge - RX7 brake adapter | aussiefan | 5 | 15,041 |
04-18-2025 05:21 PM Last Post: Gintrapper |
| WTF is that? speedodrive sender adaptor thingy.... | fax0815 | 8 | 15,713 |
09-14-2015 12:16 PM Last Post: pack |
| RX7 Calipers with Rota Grid V ET0 15x8' | pack | 11 | 18,904 |
02-06-2015 11:28 AM Last Post: mad.matt |
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 13,556 |
07-21-2014 09:12 PM Last Post: Bean |
| T3 rack adaptor bushing | TheGerman | 4 | 8,567 |
03-09-2012 12:32 AM Last Post: TheGerman |
![AEU86 AE86 - RX7 brake adaptor brackets - [Image: AEU86 AE86 - RX7 brake adaptor brackets -]](http://i57.photobucket.com/albums/g239/N2AE86/memberbanner1jpg.jpg)
