RX7 brake adaptor brackets -
08-26-2008, 03:04 PM
Does anyone know where I can get hold of the files for the brackets that Hen has so kindly developed.
Speaking to a chap who will potentially be able to make a set for me but he would like the cad files (already supplied him the available diagrams etc)
If anyone can help that would be greatly appreciated.
Cheers
James
[Image: AEU86 AE86 - RX7 brake adaptor brackets -]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
08-27-2008, 05:30 AM
Many people say that the surface area of the picton of the AE86 is just as large as the twin pistons of the FC3S.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
08-27-2008, 10:35 AM
Rx7 caliper is 4 piston - and also alloy so despite their size they are quite a bit lighter than the small stock cast caliper. Wink
08-27-2008, 12:59 PM
Why is it bad that the piston area is the same as the original caliper?
You have to balance changing of piston area with disc size to get the brake balance you want (ignoring bias adjustment via balance bar or pressure regulator).
If you want to keep the same rear brakes and fit larger front discs then you should reduce the front piston area.
If you want to increase the front and rear disc sizes you might want to keep the piston area of the front caliper the same.
The RX7 4 pots are alloy so are lighter and also you should get better brake feel (they should be stiffer but don't assume an alloy 4 ot is automatically stiffer as aluminium is not as stiff are steel) and pad wear will be more even/reduced.
08-27-2008, 02:48 PM
So with all that said .. does anyone have the cad file or know where I can get it? Big Grin Very keen to have these brackets made up.
Someone must have the file handy?
09-01-2008, 06:15 AM
PM me your email addy and I'll send you a zip file. These brackets are designed to fit a 2001 mini cooper S disk.
Search for Oly or Blue86 (?) on ae86drivingclub for his write up.
regards,
Chris
09-01-2008, 11:18 PM
Just contact Aussiefan on this forum , I think he does a good job on this !
fil
Filh
Save the RWD cars
09-08-2008, 01:15 PM
Chrisso, thanks for the offer - Aussie Fan kindly hooked me up.
Need to see if I can buy these now as the machine shop I was intending on using have said they dont think they can make them. Sad
Hopefully Aussie Fan has a spare set. Smile
  WTF is that? speedodrive sender adaptor thingy.... fax0815 8 12,132 09-14-2015 12:16 PM
Last Post: pack
  RX7 Calipers with Rota Grid V ET0 15x8' pack 11 13,533 02-06-2015 11:28 AM
  4 Link setup and Traction brackets Jezza_hr 5 10,225 07-21-2014 09:12 PM
  sharing knowledge - RX7 brake adapter aussiefan 5 10,921 04-24-2012 10:58 AM
Last Post: Roku_trueno
  T3 rack adaptor bushing TheGerman 4 6,581 03-09-2012 12:32 AM
Last Post: TheGerman
