Removing brake servo (booster)
09-17-2011, 01:40 PM
What a job Huh
AE86 right hand drive small port inlet manifold.
Take lower dash panel off.
Drop steering column and support bracket.
1ft long 1/4" extension bar to release "hidden" servo nut from inside.
Remove pin and clip from brake pedal.
Remove master cylinder.
Servo will not come out of space with smallport inlet manifold fitted Banging head
Release engine mount on inlet side.
Jack engine on block of wood under sump. Careful to check all pipes etc.
Remove clevis pin connection from servo.
servo will now just come out through gap. Hurray!
Replacement servo fitted back in without removing clevis pin connection.
Mine was made more complicated as I had also to remove a sumpguard.
  Brake booster braket Mylesmck 0 1,139 05-19-2023 12:56 PM
Last Post: Mylesmck
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 4,513 03-22-2016 09:43 PM
Last Post: ditn
  removing light switch ? (fixed) MC_JP 10 17,476 09-18-2014 05:16 PM
Last Post: MC_JP
  Removing front window trim zenki 7 12,846 09-07-2014 08:36 PM
  Replacing brake servo/booster Eifelaner 6 7,068 08-17-2013 11:19 PM
Last Post: Eifelaner
