Ricks project AE85 (Back together with dyno results)
12-14-2006, 11:31 AM
Rick Wrote:From a Hilux of course From the last model of Hilux, or? Which modifications did you do on it so it can fit to ae85? BTW - great project |
12-14-2006, 12:27 PM
Sephiroth Wrote:From the last model of Hilux, or? The diff I am using is from a 4x4 Hilux Surf mid 90's. Bascially I choped all the mounts off the hilux diff and the ae85 diff then re-welded the ae85 mounts onto the hilux diff, restuded, made new sway bar mounts, made new brackets for bakes. (That was just an over view its a bit harder than it sounds) The diff is not shortened and I think is the widest hilux diff you can get which is about 1470-1480mm from disc to disc, but they come in quite a range of widths Corolla Levin SR 1984 AE-85 (Project car) Corolla Runx Z 2002 (Runabout) |
12-14-2006, 12:38 PM
Rick Wrote:The diff I am using is from a 4x4 Hilux Surf mid 90's. Bascially I choped all the mounts off the hilux diff and the ae85 diff then re-welded the ae85 mounts onto the hilux diff, restuded, made new sway bar mounts, made new brackets for bakes. (That was just an over view its a bit harder than it sounds) Thanks for the info Hope to see it drifting soon |
12-19-2006, 01:15 AM
Heya Rick. Good to see another Kiwi on here! I saw your project on Toyspeed as well, im AE86less.
Where on earth did you find such a nicely nanna'd ae85? Im lookin' at selling my rusty, faulty hatch to buy another, better one. I don't mind if it's hatch or notch, just so long as the body's good. Do you do your own welding? Cause I've heard that it costs quite alot to change the mounts on the Hilux diff. Hehe, theres good logic there ^ people go all out to find a ae86 for a race car then strip out all the good stuff. They should just leave them for me to make a nice road car. Current Cars: '86 SE82 FX GT '88 NZ New KE70 Van (Daily) |
12-19-2006, 05:44 AM
hey rick,
nice to see some more kiwis floating around. last time i saw you i think was at the '86 meet in one tree hill (then bk westgate). i must put up some pics of mine soon. so how hard was it to put the ae92 brakes on the rear? you re-drill for 4x114.3mm pcd? just i've got a facelift ae92 gt sitting in my carport (yay small port!) wondering whether i strip it & dump it or takes things off like brakes and swap them over to my levin... scott ps gotta agree with yourself & nz trueno - the price of ae86's i almost cry when i see one torn up, stripped down and then abused. they are rare enough as it is! i say if you wanna convert, do the 85. for us nzers anyways (i know some countries have no choice) :wink: |
12-19-2006, 10:56 PM
which subaru is that from , any measuerements ? thx. |
12-19-2006, 10:59 PM
wow...an oil cooler that blocks off the airflow to the radiator. Not trying to be sarcastic, but if your routing the oil lines for full flow (in stock configuration this setup would be wasted money), I would put in a thermostatic bypass. This thing will keep your oil from heating up otherwise, which will induce extra wear on the engine.
12-19-2006, 11:02 PM
isnt that a w2a ic heat exchanger... ? NOT FOR OIL
12-19-2006, 11:09 PM
Where do you see any fittings for air piping? Those pipes look more suited for water or oil. bit tiny for an intercooler, and certainly a very poor design if it is.
He said it's a pre-radiator, but the point of having 2 radiators is really beyond me. FABRICA MI DIEM, PVNC! |
12-19-2006, 11:23 PM
i think he means the heat exchanger for a water-to-air intercooler.
usually run a small radiator to cool the water that goes in the intercooler as well... a bit like air-conditioning. stealth points = +++ means it is slightly more complex, but in my books much better than the old air-to-air intercooler. air to air don't do much unless you've got high air flow across them (and they tend to block the airflow from the radiator too) |
Ae85 | Minidaxman | 4 | 3,462 |
04-20-2021 09:57 PM Last Post: banpei |
time to get her back on the road.. | worholm | 4 | 6,413 |
01-21-2017 09:33 AM Last Post: worholm |
AE85 Power! From 175HP 20v to 202HP F20 | 4000GT | 23 | 30,328 |
10-16-2014 02:53 PM Last Post: mad.matt |
Sam's AE85 Conversion | Sambo | 2 | 14,465 |
05-20-2014 05:03 AM Last Post: Sambo |
Stalkers daily AE85 - 7AGE | stalker | 32 | 44,057 |
12-28-2011 02:28 PM Last Post: stalker |
