S13 Front conversion help (S14/S15?)
09-27-2014, 01:25 PM (This post was last modified: 09-27-2014 01:27 PM by asyrigos.)
RE: S13 Front conversion help (S14/S15?)
I have the S13 front conversion for quite a while (4 years) with numerous track days and I am very happy with it. It's 4x114.3 and I am using the stock S13 breaks which are more than enough for my horsepower 160hp 4AGZE).
I didn't see any reason so far to consider an S14/S15 conversion.
There are a couple of important points though to make this a success:
If you intend to lower the car significantly you definitely need an S13 roll center adjuster to correct the front geometry. I am using the Nagisa Auto one and I am very happy with it.
You need to test and tune the S13 suspension for the light weight AE86. Most of them come tuned for the heavy front weight of S13. This means lighter springs and different valving of the shocks.
Haven't experienced any bump steering or other issue so far but got my eyes open for it.
The only drawback is the heavy steering wheel but I can leave with it....
If you need anything else let me know.
(09-01-2014 08:49 AM)4000GT Wrote:  Hi guys, need help, the front PCD I need is 5X114, and I am wondering if I can use the S14 or S15 suspension? I dont see many people using this only S13, wondering if thats to do with the PCD or other limitations?
If you need 5x114 then you need S14/S15 suspension. If you have 16" or larger wheels then it makes sense to go after an aftermarket front hub which will roll center as well....
1986 Toyota Corolla AE86 Levin Kouki Coupe Panda White/Black
2002 Toyota MR2/MR-S T-Sport Blue Mica
Messages In This Thread
RE: S13 Front conversion help - Martynas - 08-27-2014, 02:27 PM
RE: S13 Front conversion help (S14/S15?) - asyrigos - 09-27-2014 01:25 PM
  20v Blacktop conversion.... Mylesmck 0 402 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,027 02-08-2024 10:30 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 3,047 01-06-2022 10:34 AM
Last Post: ps13michi
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 5,179 11-05-2021 08:17 PM
Last Post: gh0st
  AE86 single wiper conversion kazi 6 9,225 08-26-2017 08:47 PM
Last Post: kazi
