Standard ECU Capabilities
01-03-2009, 06:46 PM
What is the maximum capibility of the standard ECU?
272 8.1 Cams ? or 264?
What about ITBs?
& What about ITBs with cams?
Should know all this but, its been a while since Ive been hands on.
01-03-2009, 07:47 PM
I tried the limits of the standard....
I think the standard ecu good for "healthy" 150 hp on crank. You can reach 160hp but with lean A/F ratio. So not too safety... My engine could do 134whp on dyno ~160 on crank but with ~14 AFR at WOT.
The 272 cams with 8,1mm lift can work but too much for the standard ecu (idle and revving problems under 3000rpm). ITB's can work with standard ecu too, but it doesn't make a sense.
If you want to go for bigger cams than 264 and want really power increase with ITB's you have to buy a stand alone engine management or build one Smile.
I was in the same situation, but I built my own MegaSquirt as apardal and gon recommended.
Respect!
http://ae86.blog.hu - closed
2006 Toyota Corolla Verso 2.2 D4-D
1992 JDM Nissan Silvia PS13 RB26DETT powered
  part numbers on standard cams Alex170984 10 10,638 09-19-2013 02:53 PM
Last Post: pack
  How to adjust camber on the front using standard adjustment? JDMitch 14 19,971 06-17-2011 04:55 PM
Last Post: Andrax
  standard kp61 engine c.acton1 8 7,054 08-21-2008 09:30 PM
Last Post: c.acton1
  Standard crown wheel / pinion totta Crolla 3 4,082 03-11-2008 10:16 PM
Last Post: alimonos
  driving capabilities with a wider rear? DJexor 8 6,200 03-05-2008 02:36 PM
Last Post: DJexor
