Starter Motor
10-11-2007, 01:56 PM
Starter Motor
Hi guys, I think i need a new starter motor.
At the weekend when i was trying to start my car, there was nothing happening, no noise. After, i clean a few cables and nudged a few components, then it started. Magic Smile
so, my question, is do i just go to Toyota to get a new starter motor or what ones have you guys got and recommend?
There is only one true Nismo at AEU86
10-11-2007, 05:11 PM
Starter Motor
We have a sticky about that topic:
http://www.aeu86.org/viewtopic/starter-p...38/start=0
Perhaps that's of any use?
You can either revise the starter motor, try to get a second hand (refurbished) or a new one. You have to be careful, not every 4age startermotor will fit.
[Image: AEU86 AE86 - Starter Motor]
10-11-2007, 05:54 PM
Starter Motor
If nudging things is helping, then the starter motor itself is probably the last thing to blame (unless offcourse you nudged it with a bloody big hammer).
You probably have a loose signal wire.. check the connection first.
If the starter is turning the engine around with enough power and speed then it is likely in good enough condition.
10-12-2007, 10:09 AM
Starter Motor
Thanks guys.
Banpei, you said that not all 4age motor starter fits, please elaborate. My car is 1986 and has a AE92 engine.
Cheers
10-12-2007, 06:01 PM
Starter Motor
later 4age's often came with reduction type starters, these are better than the old direct type's, but they dont fit without a spacer I think. But dont be dissapointed if you fit a new starter and the problem hasnt gone away, you should focus more on the wiring. Next time the starter refuses to turn, take a bit of wire, and connect the signal connector on the starter directly to your +12v on the battery. Do be carefull and put it in neutral first. if the starter turns, then you have a wiring problem, not a starter problem.
10-13-2007, 12:15 PM
Starter Motor
Nisno - I had that problem with mine - allsorts of starters listed for twincams and i have a 92 engine in mine too.
I took mine off, cleaned connections and put a new battery on. problem cured - and my symptoms were EXACTLY as you describe yours!
[Image: AEU86 AE86 - Starter Motor][Image: AEU86 AE86 - Starter Motor]
  AE86 starter options max_ae86 12 32,363 07-28-2019 08:17 PM
Last Post: harkes
  Starter problems Widar 49 128,663 02-09-2015 10:11 AM
  motor oil for 16V kawo 18 30,286 11-25-2013 11:18 AM
Last Post: Apsogos
  Starter Motor Help phill 92 3 6,362 11-25-2013 11:16 AM
Last Post: Apsogos
  Starter motor questions - rebuild Jezza_hr 6 8,771 08-31-2013 03:05 PM
Last Post: Apsogos
