Stock 4A-GE specification
04-22-2013, 08:29 PM
Some ECU's went up to 7800 (mine did).. Not that it will do you any good on a stock engine.
04-22-2013, 08:46 PM
Ivan141 Wrote:Some ECU's went up to 7800 (mine did).. Not that it will do you any good on a stock engine.
Agreed, mine goes to 7800rpm stock euro spec Map ECU. And yes there is nothing from 6600, exept for more noise Wink
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-23-2013, 02:38 AM
thanks Guys, it's interesting.
Maybe we are discovering anotherdifferences between EU and US version ?
Fax0815 wow You have a great location Thumbs up!
I need to ask U Guys is there rapid curve drop above 6600rpm or is it relatively stable, just a lack of power increase ?
And where dangerous rpms begin ? by dangerous I mean clearly increased engine wear ?
  Digital speedometer on stock dashboard FanIsHere 0 1,352 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,739 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,309 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,548 03-24-2019 04:10 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,815 02-20-2016 11:48 AM
