Stock 4A-GE specification
04-22-2013, 08:29 PM
Some ECU's went up to 7800 (mine did).. Not that it will do you any good on a stock engine.
04-22-2013, 08:46 PM
Ivan141 Wrote:Some ECU's went up to 7800 (mine did).. Not that it will do you any good on a stock engine. Agreed, mine goes to 7800rpm stock euro spec Map ECU. And yes there is nothing from 6600, exept for more noise ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-23-2013, 02:38 AM
thanks Guys, it's interesting.
Maybe we are discovering anotherdifferences between EU and US version ? Fax0815 wow You have a great location ![]() I need to ask U Guys is there rapid curve drop above 6600rpm or is it relatively stable, just a lack of power increase ? And where dangerous rpms begin ? by dangerous I mean clearly increased engine wear ? |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,633 |
82mm Stock compression Pistons | apardal | 4 | 3,137 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,215 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,938 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,136 |
02-20-2016 11:48 AM Last Post: Bean |
User(s) browsing this thread:
