Suspensions and stearing setups
01-06-2007, 08:44 AM
Post: #41
Abe Wrote:The end...
Yesterday I saw that whit less Caster my car can turn whit more response, the transsitions are fast... and I like it... and today I go to the minimun caster without rub in my fender...
The problem of understeer in my car was the toe, I had positive TOE Huh and the car understeer so much... Now I have this setup:
Camber: -2º 15'
Caster: 3º 20'
TOE: -0º 01'
Now my car understeer less with gas than before whitout gas Hurray! , I cant prove it all, because the road not is good... but I have very good impresion at this moments...
Regards and thank you very much for your help Thumbs up!
0º Toe helps a LOT. Glad you have it sorted.
Caster you might want to think about reducing to 2.5º and hammering your inner fenderwells/pinchweld to clear the tire/turning radius. Extremely nice for response when doing fast corners/slalom type driving
For drifting I run 3.5º+ camber But had great results for grip with 2.5º
Taka Aono in his national champion SCCA track car ran:
2.5º camber
Unfortunately I can't remember what his caster was set too.
Andrew
  Possible turbo setups for the 4age. wannabeadrifter 3 4,984 10-29-2009 06:15 AM
Last Post: wannabeadrifter
  what do you use like suspensions ? Spy 40 46,181 04-14-2009 10:20 PM
Last Post: Uzelac
  What are your ignition timming setups? Rasteirinho 1 3,178 02-27-2008 08:42 PM
Last Post: Rasteirinho
  Electric fan setups Ivan141 22 27,602 01-05-2005 10:55 PM
Last Post: KristianAE86
User(s) browsing this thread:
