TPS
04-12-2007, 11:16 AM
TPS
Is TPS (throttle position sensor) same for all types of 4AGE engines?
I have a red top, big port, AFM engine. Can I use TPS taken from other 4AGE engines? Thx. Fun is not the straight line! |
04-12-2007, 12:59 PM
TPS
Not the same in my case (compared AE86 bluetop and smallport hi-CR AE92 redtop).
04-12-2007, 01:56 PM
TPS
I suppose that TPS is the same for big port 4AGE engines, AFM or MAP. I have problems with tuning of TPS because my throttle body has some spacing at butterfly axle so it’s impossible to adjust TPS according to manual. I had to fix throttle body first. I don’t know how much is new throttle body?
TPS and stop screw set up | kazi | 7 | 9,297 |
04-23-2017 09:40 PM Last Post: kazi |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,393 |
10-25-2013 05:13 PM Last Post: Apsogos |
TPS for carbs | totta Crolla | 7 | 7,843 |
01-30-2013 09:14 PM Last Post: totta Crolla |
tps codes | totta Crolla | 1 | 4,110 |
08-01-2010 03:05 PM Last Post: totta Crolla |
TPS 89452-12090 | gjuro | 2 | 5,395 |
05-12-2010 12:41 AM Last Post: isac |
