What's the LSD oil I should use?
07-21-2011, 07:50 PM
I'm not really particular about the brand.
I had a leak in my oil seal in one of my axle's and now i have to replace the oil so wondering what the oil should be.
thanks,
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
07-21-2011, 08:32 PM
Personally I use Castrol SAF-XJ or Redline 75W140
07-21-2011, 08:38 PM
I saw in one of the HachiRoku.net that they recommend 75w90..
Is that correct?
07-21-2011, 11:42 PM
Actually Toyota recommended SAE 90 API GL 5 and 80W90 for winter.
If you intend to use your 86 only on road, you can stay with 75W90, but don't forget to use LSD oil !
Personally, I use my 86 on road and on track for drifting.
This last application "stress" a lot the mechanics, so I prefer to use oil with an higher grade (it also help to reduce a little bit the noise)
07-25-2011, 08:13 PM
Thanks mate..
  How far should I have to push my clutch in dinkers542 4 6,078 11-29-2014 11:18 PM
Last Post: dinkers542
  trans oil, lsd oil change Apolan 9 16,898 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 30,006 06-06-2013 07:36 PM
Last Post: Deuce Cam
  All I should know about suspension before any modification damusto 20 21,186 05-24-2013 09:28 PM
Last Post: damusto
  LSD Oil, Necessary? phill 92 6 8,196 04-06-2012 05:17 PM
Last Post: Sgonzalez
